I have a SeedStudio J101 carrier board jetson nano 4 gb dev kit with jetpack 4.6.1 in it. Problem is the OS is installed in it’s internal memory(emmc) and less space is available around 1gb to do any projects. So I wanted to use sd card for the same. I have enabled the SD card proper format and while trying to move the OS to the SD card so that i can boot from the sd card i followed a series of commands from the official doc here J101 Enable SD Card - Seeed Wiki and got error at :-
Error after performing the foll:- ./copyRootToUSB.sh -p /dev/mmcblk1p1
Error:-
nvidia@ubuntu:~/bootFromUSB$ ./copyRootToUSB.sh -p /dev/mmcblk1p1
Device Path: /dev/mmcblk1p1
Target: /media/nvidia/mvnvidia
[sudo] password for nvidia:
Hit:1 https://repo.download.nvidia.com/jetson/common r32.7 InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Hit:3 https://repo.download.nvidia.com/jetson/t210 r32.7 InRelease
Get:4 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [83.3 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 DEP-11 Metadata [291 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe arm64 DEP-11 Metadata [297 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports bionic-backports/main arm64 DEP-11 Metadata [8,092 B]
Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-backports/universe arm64 DEP-11 Metadata [10.1 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports bionic-security/main arm64 DEP-11 Metadata [49.1 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe arm64 DEP-11 Metadata [56.0 kB]
Fetched 972 kB in 3s (352 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
rsync is already the newest version (3.1.2-2.1ubuntu1.5).
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common
kde-window-manager kinit kio kpackagetool5 kwayland-data kwin-common kwin-data kwin-x11 libdebian-installer4 libkdecorations2-5v5
libkdecorations2private5v5 libkf5activities5 libkf5attica5 libkf5completion-data libkf5completion5 libkf5declarative-data
libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5 libkf5idletime5
libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5 libkf5kiontlm5 libkf5kiowidgets5
libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5 libkf5quickaddons5
libkf5solid5 libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5
libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5 libkscreenlocker5
libkwin4-effect-builtins1 libkwineffects11 libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5 libqt5help5
libqt5multimedia5 libqt5multimedia5-plugins libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5 libqt5quickwidgets5
libqt5sql5 libqt5test5 libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober python3-dbus.mainloop.pyqt5 python3-icu
python3-pam python3-pyqt5 python3-pyqt5.qtsvg python3-pyqt5.qtwebkit qml-module-org-kde-kquickcontrolsaddons
qml-module-qtmultimedia qml-module-qtquick2 rdate tasksel tasksel-data
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 248 not upgraded.
10,265,934,548 94% 2.27MB/s 1:11:49 (xfr#94253, ir-chk=1002/146692)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpiCC-wrapper-data.txt" -> "mpic++-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpiCC.openmpi-wrapper-data.txt" -> "mpiCC-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpic++.openmpi-wrapper-data.txt" -> "mpic++-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpicc.openmpi-wrapper-data.txt" -> "mpicc-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpicxx-wrapper-data.txt" -> "mpic++-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpicxx.openmpi-wrapper-data.txt" -> "mpicxx-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpif77-wrapper-data.txt" -> "mpifort-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpif77.openmpi-wrapper-data.txt" -> "mpif77-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpif90-wrapper-data.txt" -> "mpifort-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpif90.openmpi-wrapper-data.txt" -> "mpif90-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/oshcc-wrapper-data.txt" -> "shmemcc-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/oshfort-wrapper-data.txt" -> "shmemfort-wrapper-data.txt" failed: Bad message (74)
rsync: recv_generator: mkdir "/media/nvidia/mvnvidia/usr/share/openmpi/amca-param-sets" failed: Bad message (74)
*** Skipping any contents from this failed directory ***
10,297,136,537 94% 2.25MB/s 1:12:45 (xfr#95506, ir-chk=1000/148181)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-btl-vader.txt.vAMDSZ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-coll-sync.txt.FYeYyz" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-dash-host.txt.3zgvng" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-errmgr-base.txt.1rT9r8" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ess-base.txt.NVQx07" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ess-hnp.txt.CjXlNz" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-hostfile.txt.TlFO6i" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mca-base.txt.SKjXKt" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mca-bml-r2.txt.gEFh8G" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mca-coll-base.txt.SM59Sb" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mca-osc-base.txt.jVaYh7" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mca-var.txt.B6ZLXc" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-api.txt.HtspiC" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-btl-base.txt.5DP71j" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-btl-openib-cpc-base.txt.Jy85ni" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-btl-openib.txt.gNNfjv" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-btl-sm.txt.rmVNvW" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-btl-tcp.txt.gy4NwJ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-coll-sm.txt.70JepG" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-common-sm.txt.eGFYFM" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-errors.txt.0hJioQ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-pml-ob1.txt.ykG2zX" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-runtime.txt.uhSwVc" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpool-base.txt.qCUPEw" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mtl-ofi.txt.kPo7LA" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mtl-psm.txt.Ilvd4H" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oob-base.txt.wHZ32X" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oob-tcp.txt.gtokSj" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oob-ud.txt.cnq67P" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-common-verbs.txt.eY6WQs" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-hwloc-base.txt.ga9QIN" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-runtime.txt.E12CQ9" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-shmem-mmap.txt.iBHxPA" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-shmem-posix.txt.gxcQg4" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-shmem-sysv.txt.wYCoSC" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-timer-linux.txt.g73Tbf" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-util.txt.4jC4IW" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-wrapper.txt.0SNWCE" failed: Bad message (74)
10,297,256,055 94% 2.25MB/s 1:12:45 (xfr#95565, ir-chk=1012/148252)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal_info.txt.qFgoUl" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-clean.txt.Ok0Rh2" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-filem-raw.txt.cc42XI" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-info.txt.Ski3kt" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-odls-base.txt.4Buc2d" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-odls-default.txt.kfh9RX" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-ps.txt.qP0L0H" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-base.txt.aKq6ir" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-md.txt.mHU919" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-ppr.txt.W2C5MW" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-resilient.txt.oEdaXJ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-rr.txt.gJyipw" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-seq.txt.6cZUii" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rtc-base.txt.Qz3aw3" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-runtime.txt.SFenyS" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-server.txt.KOZxLH" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-top.txt.IUzoix" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orted.txt.sjB2Wl" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orterun.txt.ss8wRa" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-info.txt.Yh5n0Y" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-memheap.txt.UUughM" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-spml-yoda.txt.Camt7C" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-sshmem-mmap.txt.I4Dkfu" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-sshmem-sysv.txt.y4SMSm" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-sshmem.txt.qDtXVf" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-plm-base.txt.i8Ba57" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-plm-rsh.txt.al31v6" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-plm-slurm.txt.MfDQt4" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-pmix-base.txt.caEPI3" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ras-base.txt.Qjrhd7" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ras-gridengine.txt.w8Qk69" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ras-simulator.txt.CoK5Be" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ras-slurm.txt.2C1Rmi" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-rcache-base.txt.ySvjVo" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-regex.txt.ebzRzz" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-rmaps_rank_file.txt.wv9quJ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-rtc-freq.txt.7k7iHN" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-shmem-api.txt.OxFufR" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-shmem-runtime.txt.pb5zuX" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-state-staged-hnp.txt.8qon22" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.mca-btl-openib-device-params.ini.tUgAN7" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.mpic++-wrapper-data.txt.SjeB8i" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.mpicc-wrapper-data.txt.bomgNu" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.mpifort-wrapper-data.txt.wReZ4H" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.opalc++-wrapper-data.txt.LBlEJU" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.opalcc-wrapper-data.txt.E6vkx6" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.openmpi-valgrind.supp.zyOzIo" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.ortecc-wrapper-data.txt.8SwbrH" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.shmemcc-wrapper-data.txt.1Hb8N1" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.shmemfort-wrapper-data.txt.oWvPNs" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openssh/.sshd_config.Zn1gLZ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openssh/.sshd_config.md5sum.kZXX3J" failed: Bad message (74)
10,394,651,244 94% 2.26MB/s 1:13:06 (xfr#101429, ir-chk=1085/155695)
rsync: recv_generator: mkdir "/media/nvidia/mvnvidia/usr/share/transmission/web" failed: Bad message (74)
10,407,690,629 94% 2.26MB/s 1:13:10 (xfr#102535, ir-chk=1158/157066)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.controls.ui.x0GHYo" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.playlist.ui.OgJTY6" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.preferences.ui.r4Olr8" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.properties.ui.X91F4q" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.shortcuts.ui.pRxtFU" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.totem.ui.PnKjxE" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.uri.ui.Pf9EEF" failed: Bad message (74)
11,843,686,748 95% 2.13MB/s 1:28:12 (xfr#132968, to-chk=0/192726)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1196) [sender=3.1.2]
Please help in resolving this issue
