Error while loading shared libraries: libcublas.so.10.0: cannot open shared object file: No such file or directory
I have installed CUDA-10.0 in the remote server and exported the CUDA and Lib 64 paths as the root user. And then I can able to make all the samples without any error and then logged out.
After then I logged into my normal user account using ssh. I could compile a certain code with -lcublas flag but when I ran the executable file I got the error
error while loading shared libraries: libcublas.so.10.0: cannot open shared object file: No such file or directory
Then I export only the Lib64 path from my normal user account as given Linux post installation discussion
export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64\
                         ${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
Then I can run the executable file successfully and getting correct output.
My question is
" What to do so that all the users can compile and run without every time exporting the paths from the normal user accounts?"
They all need to set that environment variable. In a cluster environment this is often done through the module system. Type “man module” in linux. I’m sure there are other methods as well.
My variable
echo $LD_LIBRARY_PATH
/usr/local/cuda-10.2/lib:/usr/local/cuda-10.2/lib64:/usr/lib:/usr/local/cuda/targets/aarch64-linux/lib:/usr/lib:/usr/lib/aarch64-linux-gnu
already is set but I get that error. How can it be solved?
If you mean this error:
You cannot use CUDA 10.2 to satisfy a dependency on CUDA 10.0. You must use CUDA 10.0 and your LD_LIBRARY_PATH variable must point to a CUDA 10.0 install, not a CUDA 10.2 install.
