This error appears when agx xavier compiles custom code. Is there a solution?
When using sudo find / -name “libnvbuf*” it was not found either.
Looks like you don’t have the prebuilt lib in your system:
$ ll /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so*
lrwxrwxrwx 1 root root 23 Sep 17 12:13 /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so -> libnvbuf_utils.so.1.0.0
-rw-r--r-- 1 root root 45136 Sep 17 12:09 /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so.1.0.0
The libs are installed by default. It is not expected these are absent. We suggest re-flash the system image and check again.
