I’m a beginner trying to learn cuda. After installation, I was trying to compile and run all the sample programs. All programs seem to compile fine, But some don’t execute. It seems like the cuFFT library hasn’t been linked/installed properly. So any program with that dependency doesn’t execute. I get the following error:
./convolutionFFT2D: error while loading shared libraries: libcufft.so.9.1: cannot open shared object file: No such file or directory
Can anyone help me with this issue? Since I would also like to install and run tensorflow, I would like to avoid any issue related to the cuda install.
You need to make sure you have updated the LD_LIBRARY_PATH environment variable correctly. Refer to the mandatory post-install actions in the linux install guide.
and when running nvcc --version in terminal I get this:
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Apr_24_19:10:27_PDT_2019
Cuda compilation tools, release 10.1, V10.1.168
Could you please advise what might be the problem? Thank you very much.
Your relion is linked against CUDA 9.1. You cannot use CUDA 10.1 as a replacement for that. Install CUDA 9.1 (you don’t need to install the GPU driver, just the CUDA toolkit) and make sure your PATH and LD_LIBRARY_PATH variables point to your CUDA 9.1 installation.
But what I don’t understand is that relion is installed on a nas storage connected to multiple machines, and on this machine it is the only machine that gives this error while on the other machines no error appears when running relion, how comes?
Maybe because those other machines have a proper install of CUDA 9.1? Or maybe there is an install of CUDA 9.1 on the NAS and you just haven’t set your machine up properly?
I really doubt I will be able to solve this for you. I’ve given you instructions how to fix already. Its what I would do if I were faced with this, and had no other information than what is in this thread.
