I have an issue with running ELF file which is yolo 2 detector deployed in jetson nano
After the succefully of deployment when i run the ELF file from terminal i have the following error
./yolo2detectobject.elf ls :cannot access '/dev/video*:No such file or directory
usupported camera resolution.
Please select of the following supported resolutions[/code]
I tried to run the file from linux in the folder where the ELF file saved but cannot working
