Hardware Platform (Jetson / GPU) : x86 RTX 4070 super
deepStream Version : 7.1
JetPack Version (valid for Jetson only) none
TensorRT Version :10.5
NVIDIA GPU Driver Version (valid for GPU only) 570
Issue Type( questions, new requirements, bugs) questions
How to reproduce the issue ?
run deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
Requirement details :
os : ubuntu24.04
cuda : 12.6
cudnn : 9.5.0
i follow install doc to install deepstream.
shell show me
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1152 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b30_gpu0_int8.engine open error
0:00:00.123393251 186927 0x591e9c778560 WARN nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b30_gpu0_int8.engine failed
0:00:00.123408369 186927 0x591e9c778560 WARN nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b30_gpu0_int8.engine failed, try rebuild
0:00:00.123413853 186927 0x591e9c778560 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2106> [UID = 1]: Trying to create engine from model files
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1124 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-7.1/samples/models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b30_gpu0_int8.engine opened error
0:00:52.601057081 186927 0x591e9c778560 WARN nvinfer gstnvinfer.cpp:681:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2133> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-7.1/samples/models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b30_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:327 [FullDims Engine Info]: layers num: 3
0 INPUT kFLOAT input_1:0 3x544x960 min: 1x3x544x960 opt: 30x3x544x960 Max: 30x3x544x960
1 OUTPUT kFLOAT output_cov/Sigmoid:0 4x34x60 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT output_bbox/BiasAdd:0 16x34x60 min: 0 opt: 0 Max: 0
0:00:52.786258402 186927 0x591e9c778560 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Failed to query video capabilities: Invalid argument
Error while setting IOCTL
Invalid control
S_EXT_CTRLS for CUDA_GPU_ID failed
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
Invalid control
I have reinstalled the drivers and the system many times, but this did not resolve the issue. I hope you can help me.
update:
i use this docker images nvcr.io/nvidia/tensorrt:23.10-py3 build a container.
run command
docker run -it -v --ipc=host --env DISPLAY=$DISPLAY --volume /tmp/.X11-unix:/tmp/.X11-unix --device /dev/dri -d --gpus=all nvcr.io/nvidia/tensorrt:23.10-py3 /bin/bash
and same install
deepstream can work.
Same installation process, why different results?
