I’m trying to create a deepstream pipeline in order to encode a set of images into a video using nvidia hardware acceleration using nvjpegdec
and nvv4l2h265enc
. The pipeline I’ve built is the following one: appsrc block=true name=“pipeline_name.mkv" caps="image/jpeg,width=1152,height=648" ! nvjpegdec ! nvv4l2h265enc bitrate=2000000 ! h265parse ! matroskamux ! filesink location=“”folder/pipeline_name.mkv""
When running it I got the following error:
0:00:00.162009920 352925 0xffff8c7b2360 ERROR videometa gstvideometa.c:240:default_map: plane 0, no memory at offset 0
0:00:00.162020672 352925 0xffff8c7b2360 ERROR default video-frame.c:168:gst_video_frame_map_id: failed to map video frame plane 0
0:00:00.162035456 352925 0xffff8c7b2360 WARN videodecoder gstvideodecoder.c:4155:_gst_video_decoder_error:<nvjpegdec1> error: Failed to decode JPEG image
0:00:00.162042912 352925 0xffff8c7b2360 WARN videodecoder gstvideodecoder.c:4157:_gst_video_decoder_error:<nvjpegdec1> error: Buffer allocation failed, reason: ok
0:00:00.162144353 352925 0xffff8c7b2360 ERROR videometa gstvideometa.c:240:default_map: plane 0, no memory at offset 0
0:00:00.162153569 352925 0xffff8c7b2360 ERROR default video-frame.c:168:gst_video_frame_map_id: failed to map video frame plane 0
0:00:00.162162497 352925 0xffff8c7b2360 WARN videodecoder gstvideodecoder.c:4155:_gst_video_decoder_error:<nvjpegdec1> error: Failed to decode JPEG image
0:00:00.162168097 352925 0xffff8c7b2360 WARN videodecoder gstvideodecoder.c:4157:_gst_video_decoder_error:<nvjpegdec1> error: Buffer allocation failed, reason: ok
0:00:00.162330723 352925 0xffff8c7b2360 ERROR videometa gstvideometa.c:240:default_map: plane 0, no memory at offset 0
0:00:00.162339395 352925 0xffff8c7b2360 ERROR default video-frame.c:168:gst_video_frame_map_id: failed to map video frame plane 0
0:00:00.162347683 352925 0xffff8c7b2360 WARN videodecoder gstvideodecoder.c:4155:_gst_video_decoder_error:<nvjpegdec1> error: Failed to decode JPEG image
0:00:00.162353251 352925 0xffff8c7b2360 WARN videodecoder gstvideodecoder.c:4157:_gst_video_decoder_error:<nvjpegdec1> error: Buffer allocation failed, reason: ok
0:00:00.162415652 352925 0xffff8c7b2360 ERROR videometa gstvideometa.c:240:default_map: plane 0, no memory at offset 0
0:00:00.162424612 352925 0xffff8c7b2360 ERROR default video-frame.c:168:gst_video_frame_map_id: failed to map video frame plane 0
0:00:00.162431460 352925 0xffff8c7b2360 WARN videodecoder gstvideodecoder.c:4155:_gst_video_decoder_error:<nvjpegdec1> error: Failed to decode JPEG image
0:00:00.162437412 352925 0xffff8c7b2360 WARN videodecoder gstvideodecoder.c:4157:_gst_video_decoder_error:<nvjpegdec1> error: Buffer allocation failed, reason: ok
Any idea about what is causing this error and eventually how to solve it?
