Error while trying to flash Jetson orin NX using sdk-manager in Docker
I am trying to flash the Jetson Orin NX and it keeps timing out. When looking at the logs files I found the following error:
09:15:09.850 - error: Failed to send GA4 event. Error: RequestError: connect ECONNREFUSED 0.0.0.0:443
09:15:09.850 - error: siSendGAEvent failed with error: Error: connect ECONNREFUSED 0.0.0.0:443
    at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1187:16) {
  errno: -111,
  code: 'ECONNREFUSED',
  syscall: 'connect',
  address: '0.0.0.0',
  port: 443
09:38:17.640 - info: install timeout for 'Flash Jetson Linux', [Continue]
I am using the approach outlined in this link
Dump the log, please. Don’t crop any log yourself.
Please also do this, and try again without using Docker.
