I am relatively new to trying to install new libraries on my Redhat system but I am trying to install Cuda5.5 and have hit the following problem.
I have been following the directions outlined on this page. CUDA Toolkit Documentation
However when I get to the step for using “install cuda” I get the following error:
Error: Package: cuda-samples-5-5-5.5-22.x86_64 (cuda)
Requires: freeglut-devel
You could try using --skip-broken to work around the problem
I have downloaded free-glut devel from here (http://rpmfind.net//linux/RPM/opensuse/12.1/i586/freeglut-devel-100529-8.1.2.i586.html) however when I use “rpm --install freeglut-devel-100529-8.1.2.i586.rpm”
warning: freeglut-devel-100529-8.1.2.i586.rpm: Header V3 RSA/SHA256 Signature, key ID 3dbdc284: NOKEY
error: Failed dependencies:
freeglut = 100529-8.1.2 is needed by freeglut-devel-100529-8.1.2.i586
xorg-x11-Mesa-devel is needed by freeglut-devel-100529-8.1.2.i586
xorg-x11-devel is needed by freeglut-devel-100529-8.1.2.i586
Which I am less able to interpret and understand. I have tried following other tutorials for setting things up but I haven’t had much luck with those either. Any ideas? Thanks.
