Error while trying to reflash and boot from nvme
Happy Fourth!
I am trying to reflash Orin AGX 64GB dev kit using an Ubuntu 20.04.6 (x86) machine.
Adding the error messages:
19:30:47 ERROR: Flash Jetson Linux - flash: [ 0.0302 ] ERROR: failed to read rcm_state
19:30:50 ERROR: Flash Jetson Linux - flash: [ 0.0261 ] ERROR: failed to read rcm_state
19:32:01 ERROR: Flash Jetson Linux - flash: ERROR: value 0x31 is out o
19:32:01 ERROR: Flash Jetson Linux - flash: [ 0.9479 ] ERROR: value 0x31 is out of range
19:32:01 ERROR: Flash Jetson Linux - flash: [ 0.9481 ] ERROR: value 0x31 is out of range
19:32:01 ERROR: Flash Jetson Linux - flash: [ 0.9482 ] ERROR: value 0x31 is out of range
19:32:07 ERROR: Flash Jetson Linux - flash: [ 7.0176 ] ERROR:
19:32:15 ERROR: Flash Jetson Linux - flash: [ 0.0252 ] ERROR: failed to read rcm_state
19:32:18 ERROR: Flash Jetson Linux - flash: e:
19:35:51 ERROR: Flash Jetson Linux - flash: [ 0.0266 ] ERROR: failed to read rcm_state
19:36:16 ERROR: Flash Jetson Linux - flash: [ 0.8823 ] ERROR: value 0x31 is out of range
19:39:20 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.sswamyn.sh; [error]: 130032 blocks
19:39:20 ERROR: Flash Jetson Linux - flash: command terminated with error
19:39:20 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
Here is the screenshot of the errors:
Log file from the most recent attempt:
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_AGX_Orin_modules_2024-07-04_17-42-11.zip (384.2 KB)
Thank you.
Swamy
Command failed: ping6 -c 1 fe80::1%usb0. Check your network settings (firewall, VPN,…) so that it can ping fe80::1%usb0
Please check the firewall setting on your host PC.
The flashing process relies on SSH connection, so if the connection is blocked by firewalls then it will fail.
Please also check the log from the device:
