Error While trying to run DeepStream App source30_1080p_dec_infer-resnet_tiled_display_int8.txt
Hello…
I am getting the following errors while running deepstream-app source30_1080p_dec_infer-resnet_tiled_display_int8.txt. I have installed DeepStream 6.3 on Ubuntu 20.04, and I wanted to test whether is working properly or not. When I tried to run one of the samples it gave this error.
hcytech@hcytech-Blade-15-2022-RZ09-0421:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app$ sudo deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
(gst-plugin-scanner:4530): GStreamer-WARNING **: 18:24:43.027: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpeg.so’: libnvjpeg.so.12: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4530): GStreamer-WARNING **: 18:24:43.027: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4530): GStreamer-WARNING **: 18:24:43.028: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4530): GStreamer-WARNING **: 18:24:43.028: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferaudio.so’: libcufft.so.11: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4530): GStreamer-WARNING **: 18:24:43.029: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ucx.so’: libucs.so.0: cannot open shared object file: No such file or directory
** ERROR: <create_render_bin:143>: Failed to create ‘sink_sub_bin_transform1’
** ERROR: <create_render_bin:195>: create_render_bin failed
** ERROR: <create_sink_bin:831>: create_sink_bin failed
** ERROR: <create_processing_instance:956>: create_processing_instance failed
** ERROR: <create_pipeline:1576>: create_pipeline failed
** ERROR: main:697: Failed to create pipeline
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
nvstreammux: Successfully handled EOS for source_id=3
nvstreammux: Successfully handled EOS for source_id=4
nvstreammux: Successfully handled EOS for source_id=5
nvstreammux: Successfully handled EOS for source_id=6
nvstreammux: Successfully handled EOS for source_id=7
nvstreammux: Successfully handled EOS for source_id=8
nvstreammux: Successfully handled EOS for source_id=9
nvstreammux: Successfully handled EOS for source_id=10
nvstreammux: Successfully handled EOS for source_id=11
nvstreammux: Successfully handled EOS for source_id=12
nvstreammux: Successfully handled EOS for source_id=13
nvstreammux: Successfully handled EOS for source_id=14
nvstreammux: Successfully handled EOS for source_id=15
nvstreammux: Successfully handled EOS for source_id=16
nvstreammux: Successfully handled EOS for source_id=17
nvstreammux: Successfully handled EOS for source_id=18
nvstreammux: Successfully handled EOS for source_id=19
nvstreammux: Successfully handled EOS for source_id=20
nvstreammux: Successfully handled EOS for source_id=21
nvstreammux: Successfully handled EOS for source_id=22
nvstreammux: Successfully handled EOS for source_id=23
nvstreammux: Successfully handled EOS for source_id=24
nvstreammux: Successfully handled EOS for source_id=25
nvstreammux: Successfully handled EOS for source_id=26
nvstreammux: Successfully handled EOS for source_id=27
nvstreammux: Successfully handled EOS for source_id=28
nvstreammux: Successfully handled EOS for source_id=29
App run failed
I think GPU driver and CUDA toolkit are not installed normally.
You had better refer this documetion
Another option. You can use the docker from NGC
