Error with Chat RTX
Hi folks, I need help my GPU:NVIDA Geforce RTX 4060 and I get a lot of error such as
SUPPORT for ChatRTX Users
ERROR: Exception in ASGI application
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic\type_adapter.py”, line 165, in init
core_schema = _getattr_no_parents(type, ‘pydantic_core_schema’)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic\type_adapter.py”, line 97, in _getattr_no_parents
raise AttributeError(attribute)
AttributeError: pydantic_core_schema
During handling of the above exception, another exception occurred:
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\uvicorn\protocols\http\h11_impl.py”, line 406, in run_asgi
result = await app( # type: ignore[func-returns-value]
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\uvicorn\middleware\proxy_headers.py”, line 60, in call
return await self.app(scope, receive, send)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi\applications.py”, line 1054, in call
await super().call(scope, receive, send)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\applications.py”, line 113, in call
await self.middleware_stack(scope, receive, send)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\middleware\errors.py”, line 187, in call
raise exc
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\middleware\errors.py”, line 165, in call
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\middleware\cors.py”, line 93, in call
await self.simple_response(scope, receive, send, request_headers=headers)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\middleware\cors.py”, line 144, in simple_response
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\middleware\exceptions.py”, line 62, in call
await wrap_app_handling_exceptions(self.app, conn)(scope, receive, send)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette_exception_handler.py”, line 62, in wrapped_app
raise exc
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette_exception_handler.py”, line 51, in wrapped_app
await app(scope, receive, sender)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\routing.py”, line 715, in call
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\routing.py”, line 735, in app
await route.handle(scope, receive, send)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\routing.py”, line 288, in handle
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\routing.py”, line 76, in app
await wrap_app_handling_exceptions(app, request)(scope, receive, send)
raise exc
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\starlette\routing.py”, line 73, in app
response = await f(request)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi\routing.py”, line 291, in app
solved_result = await solve_dependencies(
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi\dependencies\utils.py”, line 656, in solve_dependencies
) = await request_body_to_args( # body_params checked above
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi\dependencies\utils.py”, line 881, in request_body_to_args
fields_to_extract = get_cached_model_fields(first_field.type
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi_compat.py”, line 657, in get_cached_model_fields
return get_model_fields(model)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi_compat.py”, line 284, in get_model_fields
return [
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi_compat.py”, line 285, in
ModelField(field_info=field_info, name=name)
File “”, line 6, in init
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\fastapi_compat.py”, line 110, in post_init
self._type_adapter: TypeAdapter[Any] = TypeAdapter(
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic\type_adapter.py”, line 167, in init
core_schema = _get_schema(type, config_wrapper, parent_depth=_parent_depth + 1)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic\type_adapter.py”, line 80, in get_schema
schema = gen.generate_schema(type
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 448, in generate_schema
schema = self._generate_schema(obj)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 674, in _generate_schema
return self._annotated_schema(obj)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 1496, in _annotated_schema
schema = self._apply_annotations(source_type, annotations)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 1610, in _apply_annotations
schema = get_inner_schema(source_type)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_schema_generation_shared.py”, line 82, in call
schema = self._handler(__source_type)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 1703, in new_handler
schema = metadata_get_schema(source, get_inner_schema)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 1699, in
lambda source, handler: handler(source)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 1574, in inner_handler
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 694, in _generate_schema
return self.match_type(obj)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 777, in match_type
return self._match_generic_type(obj, origin)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 801, in _match_generic_type
return self._union_schema(obj)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 988, in _union_schema
choices.append(self.generate_schema(arg))
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 781, in match_type
return self._unknown_type_schema(obj)
File “C:\Users\OMEN\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\pydantic_internal_generate_schema.py”, line 377, in _unknown_type_schema
raise PydanticSchemaGenerationError(
pydantic.errors.PydanticSchemaGenerationError: Unable to generate pydantic-core schema for <class ‘starlette.requests.Request’>. Set arbitrary_types_allowed=True in the model_config to ignore this error or implement __get_pydantic_core_schema__ on your type to fully support it.
If you got this error by calling handler() within __get_pydantic_core_schema__ then you likely need to call handler.generate_schema(<some type>) since we do not call __get_pydantic_core_schema__ on <some type> otherwise to avoid infinite recursion.
For further information visit Redirecting...
Hi there @gm124881, welcome to the NVIDIA developer forums.
Regarding ChatRTX questions please refer to this post: SUPPORT for ChatRTX Users
I don’t got anything from the support
This topic was automatically closed after 5 days. New replies are no longer allowed.
