• Jetson AGX Xavier
• Deepstream 6.0
• JetPack 4.6
• TensorRT 8.0.1
• NVIDIA GPU Driver 32.6.1
Hi i’m trying to convert this model: face-recognition-resnet100-arcface-onnx — OpenVINO™ documentation
with this config file:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
labelfile-path=/home/cv/Desktop/Mask-Detection/Deepstream-app/labels.txt
model-engine-file=/home/cv/Desktop/Mask-Detection/Deepstream-app/arcfaceresnet100-8.onnx_b1_gpu0_fp32.engine
onnx-file=/home/cv/Desktop/Mask-Detection/Deepstream-app/arcfaceresnet100-8.onnx
infer-dims=3;112;112
uff-input-order=0
uff-input-blob-name=input_1
output-tensor-meta=1
batch-size=1
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
network-type=1
num-detected-classes=1
interval=0
gie-unique-id=1
output-blob-names=output_cov/Sigmoid;output_cov/Sigmoid
But got this error
Now playing...
0:00:00.170113226 20826 0x558420f0c0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
0:00:55.668094488 20826 0x558420f0c0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /home/cv/Desktop/Mask-Detection/Deepstream-app/arcfaceresnet100-8.onnx_b1_gpu0_fp32.engine successfully
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT data 3x112x112
1 OUTPUT kFLOAT fc1 512
ERROR: [TRT]: Cannot find binding of given name: output_cov/Sigmoid
0:00:55.790537079 20826 0x558420f0c0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1868> [UID = 1]: Could not find output layer 'output_cov/Sigmoid' in engine
0:00:55.790584633 20826 0x558420f0c0 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1868> [UID = 1]: Could not find output layer 'output_cov/Sigmoid' in engine
0:00:55.803115932 20826 0x558420f0c0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary1-nvinference-engine> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/dstest2_sgie1_config.txt sucessfully
Deserialize yoloLayer plugin: yolo_93
Deserialize yoloLayer plugin: yolo_96
Deserialize yoloLayer plugin: yolo_99
0:00:55.946087226 20826 0x558420f0c0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 40001]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 40001]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/model_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 4
0 INPUT kFLOAT data 3x640x640
1 OUTPUT kFLOAT yolo_93 24x80x80
2 OUTPUT kFLOAT yolo_96 24x40x40
3 OUTPUT kFLOAT yolo_99 24x20x20
0:00:55.946237441 20826 0x558420f0c0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 40001]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 40001]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/model_b1_gpu0_fp16.engine
0:00:55.952427215 20826 0x558420f0c0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 40001]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/dstest2_pgie_config.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
Running...
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: aacparse0
Decodebin child added: avdec_aac0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
In cb_newpad
In cb_newpad
1
File opened
And after loading this model (it converted sucessfully) info->inferDims.numElements equals 0
So how to convert this model to .engine?
