This is on the Nano
After finishing with the SDK Manager, but before installing DS 4.0,
it seems that gstreamer is already installed.
gst-inspect-1.0 version 1.14.1
GStreamer 1.14.4
I deleted the gstreamer cache and ran gst-inspect-1.0. Perfect, no problem.
Then following the DS 4.0 instructions I did this:
$ sudo apt-get install
libssl1.0.0
libgstreamer1.0-0
gstreamer1.0-tools
gstreamer1.0-plugins-good
gstreamer1.0-plugins-bad
gstreamer1.0-plugins-ugly
gstreamer1.0-libav
libgstrtspserver-1.0-0
libjansson4
This resulted in
gst-inspect-1.0 version 1.14.4
GStreamer 1.14.4
I got
(gst-plugin-scanner:2885): GLib-GObject-WARNING **: 10:05:59.806: cannot register existing type ‘GstInterpolationMethod’
(gst-plugin-scanner:2885): GLib-GObject-CRITICAL **: 10:05:59.806: g_param_spec_enum: assertion ‘G_TYPE_IS_ENUM (enum_type)’ failed
(gst-plugin-scanner:2885): GLib-GObject-CRITICAL **: 10:05:59.806: validate_pspec_to_install: assertion ‘G_IS_PARAM_SPEC (pspec)’ failed
followed by normal output.
This is before any DS 4.0 specific files were installed.
