Error with mamba and conda when building morpheus release container
I am running a p3.2xlarge ec2 instance running a Tesla V100-SXM2-16GB, spun up with the prebuilt NVIDIA GPU-Optimized AMI https://aws.amazon.com/marketplace/pp/prodview-7ikjtg3um26wq
I am getting an error when attempting to run the ./docker/build_container_release.sh script [Getting Started with Morpheus - NVIDIA Docs], which seems to do with conda / mamba.
ubuntu@ip-172-31-47-174:~/morpheus$ ./docker/build_container_release.sh
Building morpheus: with args...
   CUDA_MAJOR_VER             : 12
   CUDA_MINOR_VER             : 5
   CUDA_REV_VER               : 1
   FROM_IMAGE                 : nvidia/cuda
   LINUX_DISTRO               : ubuntu
   LINUX_VER                  : 22.04
   MORPHEUS_ROOT_HOST         : .
   MORPHEUS_SUPPORT_DOCA      : OFF
   MORPHEUS_BUILD_MORPHEUS_LLM: ON
   PYTHON_VER                 : 3.10
   COMMAND: docker build -t nvcr.io/nvidia/morpheus/morpheus:v25.02.00a-runtime --target runtime --build-arg CUDA_MAJOR_VER=12 --build-arg CUDA_MINOR_VER=5 --build-arg CUDA_REV_VER=1 --build-arg FROM_IMAGE=nvidia/cuda --build-arg LINUX_DISTRO=ubuntu --build-arg LINUX_VER=22.04 --build-arg MORPHEUS_ROOT_HOST=. --build-arg MORPHEUS_SUPPORT_DOCA=OFF --build-arg MORPHEUS_BUILD_MORPHEUS_LLM=ON --build-arg MORPHEUS_BUILD_MORPHEUS_DFP=ON --build-arg PYTHON_VER=3.10 --network=host  -f /home/ubuntu/morpheus/docker/Dockerfile .
> ERROR [conda_bld_morpheus 3/3] RUN --mount=type=cache,id=workspace_cache,target=/workspace/.cache,sharing=locked     --mount=type=cache,id=con  528.1s
 => CACHED [git_clone 1/1] RUN --mount=type=bind,source=.,target=/opt/host_repo     source activate morpheus &&    git clone file:///opt/host_repo/.  0.0s
 > [conda_bld_morpheus 3/3] RUN --mount=type=cache,id=workspace_cache,target=/workspace/.cache,sharing=locked     --mount=type=cache,id=conda_pkgs,target=/opt/conda/pkgs,sharing=locked     /opt/conda/bin/mamba install -y -n base -c conda-forge "git-lfs" &&    source activate base &&    git lfs install &&    git config --global --add safe.directory "*" &&    cd . &&    MORPHEUS_PYTHON_BUILD_STUBS=OFF CONDA_BLD_PATH=/opt/conda/conda-bld ./ci/conda/recipes/run_conda_build.sh morpheus:
1.293 warning  libmamba Cache file "/opt/conda/pkgs/cache/497deca9.json" was modified by another program
1.294 warning  libmamba Cache file "/opt/conda/pkgs/cache/09cdf8bf.json" was modified by another program
24.35 Transaction
24.35
24.35   Prefix: /opt/conda
24.35
24.35   Updating specs:
24.35
24.35    - git-lfs
24.35    - ca-certificates
24.35    - certifi
24.35    - openssl
24.35
24.35
24.35   Package    Version  Build       Channel           Size
24.35 ──────────────────────────────────────────────────────────
24.35   Install:
24.35
24.35   + git-lfs    3.6.0  h647637d_0  conda-forge     Cached
24.35
24.35   Summary:
24.35
24.35   Install: 1 packages
24.35
24.35   Total download: 0 B
24.35
24.35
24.35
24.85
24.85 Looking for: ['git-lfs']
24.85
24.85
24.85 Pinned packages:
24.85   - python 3.10.*
24.85
24.85
24.85
24.85 Downloading and Extracting Packages: ...working... done
24.85 Preparing transaction: done
24.95 Verifying transaction: done
25.05 Executing transaction: done
25.71 Updated Git hooks.
25.71 Git LFS initialized.
25.76 Running conda-build for morpheus vv25.02.00a...
25.76 ++ conda mambabuild --use-local --build-id-pat '{n}-{v}' -c conda-forge -c huggingface -c rapidsai -c rapidsai-nightly -c nvidia -c nvidia/label/dev -c pytorch -c defaults ci/conda/recipes/morpheus
26.77 INFO:conda_index.index.convert_cache:Migrate database
515.9 ninja: build stopped: subcommand failed.
517.5 Traceback (most recent call last):
517.5   File "/opt/conda/bin/conda-mambabuild", line 10, in <module>
517.5     sys.exit(main())
517.5   File "/opt/conda/lib/python3.10/site-packages/boa/cli/mambabuild.py", line 301, in main
517.5     call_conda_build(action, config)
517.5   File "/opt/conda/lib/python3.10/site-packages/boa/cli/mambabuild.py", line 273, in call_conda_build
517.5     result = api.build(
517.5   File "/opt/conda/lib/python3.10/site-packages/conda_build/api.py", line 250, in build
517.5     return build_tree(
517.5   File "/opt/conda/lib/python3.10/site-packages/conda_build/build.py", line 3638, in build_tree
517.5     packages_from_this = build(
517.5   File "/opt/conda/lib/python3.10/site-packages/conda_build/build.py", line 2711, in build
517.5     newly_built_packages = bundlers[pkg_type](output_d, m, env, stats)
517.5   File "/opt/conda/lib/python3.10/site-packages/conda_build/build.py", line 1784, in bundle_conda
517.5     utils.check_call_env(
517.5   File "/opt/conda/lib/python3.10/site-packages/conda_build/utils.py", line 405, in check_call_env
517.5     return _func_defaulting_env_to_os_environ("call", *popenargs, **kwargs)
517.5   File "/opt/conda/lib/python3.10/site-packages/conda_build/utils.py", line 381, in _func_defaulting_env_to_os_environ
517.5     raise subprocess.CalledProcessError(proc.returncode, _args)
517.5 subprocess.CalledProcessError: Command '['/usr/bin/bash', '-e', '/opt/conda/conda-bld/morpheus-split-25.02.00a/work/morpheus_build.sh']' returned non-zero exit status 1.
Dockerfile:264
 263 |
 264 | >>> RUN --mount=type=cache,id=workspace_cache,target=/workspace/.cache,sharing=locked \
 265 | >>>     --mount=type=cache,id=conda_pkgs,target=/opt/conda/pkgs,sharing=locked \
 266 | >>>     # Install git-lfs before running the build to avoid errors during conda build
 267 | >>>     /opt/conda/bin/mamba install -y -n base -c conda-forge "git-lfs" &&\
 268 | >>>     source activate base &&\
 269 | >>>     git lfs install &&\
 270 | >>>     # Need to get around recent versions of git locking paths until they are deemed safe
 271 | >>>     git config --global --add safe.directory "*" &&\
 272 | >>>     # Change to the morpheus directory and build the conda package
 273 | >>>     cd ${MORPHEUS_ROOT_HOST} &&\
 274 | >>>     MORPHEUS_PYTHON_BUILD_STUBS=OFF CONDA_BLD_PATH=/opt/conda/conda-bld ./ci/conda/recipes/run_conda_build.sh morpheus
 275 |
ERROR: failed to solve: process "/bin/bash -c /opt/conda/bin/mamba install -y -n base -c conda-forge \"git-lfs\" &&    source activate base &&    git lfs install &&    git config --global --add safe.directory \"*\" &&    cd ${MORPHEUS_ROOT_HOST} &&    MORPHEUS_PYTHON_BUILD_STUBS=OFF CONDA_BLD_PATH=/opt/conda/conda-bld ./ci/conda/recipes/run_conda_build.sh morpheus" did not complete successfully: exit code: 1
GPU and driver details:
ubuntu@ip-172-31-47-174:~$ nvidia-smi
Wed Nov 27 14:42:57 2024
| NVIDIA-SMI 550.54.15              Driver Version: 550.54.15      CUDA Version: 12.4     |
|   0  Tesla V100-SXM2-16GB           On  |   00000000:00:1E.0 Off |                    0 |
| N/A   30C    P0             23W /  300W |       0MiB /  16384MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|  No running processes found                                                             |
