I am using L4T 32.6.1 on a custom carrier board (JetxonTX2 4GB).
I burned fuse with the following command.
$ sudo ./odmfuse.sh -i 0x18 -k ../rsa_priv.pem -S ../sbk.key <device_name>
*** The fuse configuration is saved in bootloader/odmfuse_pkc.xml
*** The ODM fuse has been burned successfully.
*** done.
Contents of odmfuse_pkc.xml
$ cat bootloader/odmfuse_pkc.xml
<genericfuse MagicId="0x45535546" version="1.0.0">
<fuse name="SecureBootKey" size="16" value="0x******************************" />
<fuse name="PublicKeyHash" size="32" value="0x****************************************************************" />
<fuse name="BootSecurityInfo" size="4" value="0x6" />
</genericfuse>
Error with odmfuseread
$ sudo ./odmfuseread.sh -i 0x18 -k ../rsa_priv.pem -S ../sbk.key <device_name>
Error: ECID read failed.
The target board must be attached in RCM mode.
According to this post, it seems that odm_production_mode needs to be programmed as well.
I followed this post and burned the fuses using the following command.
$ sudo BOARDID=3489 BOARDSKU=0888 FAB=300 ./odmfuse.sh --noburn -i 0x18 --auth SBKPKC -p -k ../rsa_priv.pem -S ../sbk.key <device_name>
$ mkdir fuseblob
$ tar -xf fuseblob.tbz2 -C fuseblob/
$ cd fuseblob/bootloader
$ sudo ./fusecmd.sh
fusecmd log: fusecmd_m.log (4.3 KB)
odmfuse_pkc.xml is as follows.
$ cat fuseblob/bootloader/odmfuse_pkc.xml
<fuse name="SecurityMode" size="4" value="0x1" />
</genericfuse>
But it still errors.
How can I avoid ECID read failure?
Please tell me what is wrong.
