First I got the error, prepare_pascal_voc_data.sh doesnot exist. SO I downloaded the file prepare_pascal_voc_data.sh from the repo and tried it. I am getting the following error,
./prepare_pascal_voc_data.sh /data/VOCtrainval_11-May-2012.tar ./voc-data
Expanding /data/VOCtrainval_11-May-2012.tar
tar: /data/VOCtrainval_11-May-2012.tar: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
Copying data into ./voc-data
Processing train data
./prepare_pascal_voc_data.sh: line 27: /home/brp/Downloads/segmentation/tmp_files/VOCdevkit/VOC2012/ImageSets/Segmentation/train.txt: No such file or directory
Processing val data
./prepare_pascal_voc_data.sh: line 27: /home/brp/Downloads/segmentation/tmp_files/VOCdevkit/VOC2012/ImageSets/Segmentation/val.txt: No such file or directory
Done!
I also tried after cloning the whole digits repo and still with the same error.
Please provide your suggestion. Thanks in advance.
./prepare_pascal_voc_data.sh: line 27: /home/brp/Digits folder from github/DIGITS/examples/semantic-segmentation/tmp_files/VOCdevkit/VOC2012/ImageSets/Segmentation/train.txt: No such file or directory
Processing val data
./prepare_pascal_voc_data.sh: line 27: /home/brp/Digits folder from github/DIGITS/examples/semantic-segmentation/tmp_files/VOCdevkit/VOC2012/ImageSets/Segmentation/va
and with the .tar at home directory, I am getting the following error:
bash: ./prepare_pascal_voc_data.sh: No such file or directory
The .tar file is at /home/DIGITS/examples/semantic-segmentation. I also tried with home directory. Am I doing it wrong??
It would not appear that you are passing the correct path to the tarball to the script. If the tar file is located at /home/DIGITS/examples/semantic-segmentation , can you try cd’ing back to the directory with the prepare_pascal_voc_data.sh script and running this?
