Error with Texture
Hello ,
i am trzing to compile the example from github GPU-path-tracing-tutorial
but i am facing the below error
“Error (active) E0864 texture is not a template”
, i am using CUDA 9.2 and VS2017 I already able to build other simple example i programed with CUDA but without using textures.
i tried to remove CUDA and VS and reinstall them but the same problem appears.
also i modified the solution build file with adding the foloowing line to use previous build tool and it works with my simple example.
*  CUDA based triangle mesh path tracer using BVH acceleration by Sam lapere, 2016
*  BVH implementation based on real-time CUDA ray tracer by Thanassis Tsiodras,
*  http://users.softlab.ntua.gr/~ttsiod/cudarenderer-BVH.html
*  Interactive camera with depth of field based on CUDA path tracer code
*  by Peter Kutz and Yining Karl Li, https://github.com/peterkutz/GPUPathTracer
*  This program is free software; you can redistribute it and/or modify
*  it under the terms of the GNU General Public License as published by
*  the Free Software Foundation; either version 2 of the License, or
*  (at your option) any later version.
*  This program is distributed in the hope that it will be useful,
*  but WITHOUT ANY WARRANTY; without even the implied warranty of
*  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
*  GNU General Public License for more details.
*  You should have received a copy of the GNU General Public License
*  along with this program; if not, write to the Free Software
*  Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
#include <iostream>
#include <fstream>
#include <string>
#include <vector>
#include <cuda.h>
#include <math_functions.h>
#include <vector_types.h>
#include <vector_functions.h>
#include "device_launch_parameters.h"
#include "cutil_math.h"
#include "C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\extras\CUPTI\include\GL\glew.h"
#include "C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\extras\CUPTI\include\GL\glut.h"
#include <cuda_runtime.h>
#include <cuda_gl_interop.h>
#include <curand.h>
#include <curand_kernel.h>
#include "cuda_pathtracer.h"
#define M_PI 3.1415926535897932384626422832795028841971f
#define TWO_PI 6.2831853071795864769252867665590057683943f
#define NUDGE_FACTOR     1e-3f  // epsilon
#define samps  1 // samples
#define BVH_STACK_SIZE 32
#define SCREEN_DIST (height*2)
int texturewidth = 0;
int textureheight = 0;
int total_number_of_triangles;
__device__ int depth = 0;
// Textures for vertices, triangles and BVH data
// (see CudaRender() below, as well as main() to see the data setup process)
texture<uint1, 1, cudaReadModeElementType> g_triIdxListTexture;
texture<float2, 1, cudaReadModeElementType> g_pCFBVHlimitsTexture;
texture<uint4, 1, cudaReadModeElementType> g_pCFBVHindexesOrTrilistsTexture;
texture<float4, 1, cudaReadModeElementType> g_trianglesTexture;
Vertex* cudaVertices;
float* cudaTriangleIntersectionData;
int* cudaTriIdxList = NULL;
float* cudaBVHlimits = NULL;
int* cudaBVHindexesOrTrilists = NULL;
Triangle* cudaTriangles = NULL;
Camera* cudaRendercam = NULL;
struct Ray {
	float3 orig;	// ray origin
	float3 dir;		// ray direction
	__device__ Ray(float3 o_, float3 d_) : orig(o_), dir(d_) {}
enum Refl_t { DIFF, METAL, SPEC, REFR, COAT };  // material types
struct Sphere {
	float rad;				// radius
	float3 pos, emi, col;	// position, emission, color
	Refl_t refl;			// reflection type (DIFFuse, SPECular, REFRactive)
	__device__ float intersect(const Ray &r) const { // returns distance, 0 if nohit
													 // Ray/sphere intersection
													 // Quadratic formula required to solve ax^2 + bx + c = 0
													 // Solution x = (-b +- sqrt(b*b - 4ac)) / 2a
													 // Solve t^2*d.d + 2*t*(o-p).d + (o-p).(o-p)-R^2 = 0
		float3 op = pos - r.orig;  //
		float t, epsilon = 0.01f;
		float b = dot(op, r.dir);
		float disc = b*b - dot(op, op) + rad*rad; // discriminant
		if (disc<0) return 0; else disc = sqrtf(disc);
		return (t = b - disc)>epsilon ? t : ((t = b + disc)>epsilon ? t : 0);
__device__ Sphere spheres[] = {
	// sun
	{ 1.6,{ 0.0f, 2.8, 0 },{ 6, 4, 2 },{ 0.f, 0.f, 0.f }, DIFF },  // 37, 34, 30  X: links rechts Y: op neer
																   //{ 1600, { 3000.0f, 10, 6000 }, { 17, 14, 10 }, { 0.f, 0.f, 0.f }, DIFF },
																   // horizon sun2
																   //	{ 1560, { 3500.0f, 0, 7000 }, { 50, 25, 2.5 }, { 0.f, 0.f, 0.f }, DIFF },  //  150, 75, 7.5
																   // sky
																   //{ 10000, { 50.0f, 40.8f, -1060 }, { 0.1, 0.3, 0.55 }, { 0.175f, 0.175f, 0.25f }, DIFF }, // 0.0003, 0.01, 0.15, or brighter: 0.2, 0.3, 0.6
	{ 10000,{ 50.0f, 40.8f, -1060 },{ 0.51, 0.51, 0.51 },{ 0.175f, 0.175f, 0.25f }, DIFF },
	// ground
	{ 100000,{ 0.0f, -100001.1, 0 },{ 0, 0, 0 },{ 0.5f, 0.0f, 0.0f }, COAT },
	{ 100000,{ 0.0f, -100001.2, 0 },{ 0, 0, 0 },{ 0.3f, 0.3f, 0.3f }, DIFF }, // double shell to prevent light leaking
																			  // horizon brightener
	{ 110000,{ 50.0f, -110048.5, 0 },{ 3.6, 2.0, 0.2 },{ 0.f, 0.f, 0.f }, DIFF },
	// mountains
	//{ 4e4, { 50.0f, -4e4 - 30, -3000 }, { 0, 0, 0 }, { 0.2f, 0.2f, 0.2f }, DIFF },
	// white Mirr
	{ 1.1,{ 1.6, 0, 1.0 },{ 0, 0.0, 0 },{ 0.9f, .9f, 0.9f }, SPEC }
	// Glass
	//{ 0.3, { 0.0f, -0.4, 4 }, { .0, 0., .0 }, { 0.9f, 0.9f, 0.9f }, DIFF },
	// Glass2
	//{ 22, { 87.0f, 22, 24 }, { 0, 0, 0 }, { 0.9f, 0.9f, 0.9f }, SPEC },
// Create OpenGL BGR value for assignment in OpenGL VBO buffer
__device__ int getColor(Vector3Df& p)  // converts Vector3Df colour to int
	return (((unsigned)p.z) << 16) | (((unsigned)p.y) << 8) | (((unsigned)p.x));
// Helper function, that checks whether a ray intersects a bounding box (BVH node)
__device__ bool RayIntersectsBox(const Vector3Df& originInWorldSpace, const Vector3Df& rayInWorldSpace, int boxIdx)
	// set Tnear = - infinity, Tfar = infinity
	// For each pair of planes P associated with X, Y, and Z do:
	//     (example using X planes)
	//     if direction Xd = 0 then the ray is parallel to the X planes, so
	//         if origin Xo is not between the slabs ( Xo < Xl or Xo > Xh) then
	//             return false
	//     else, if the ray is not parallel to the plane then
	//     begin
	//         compute the intersection distance of the planes
	//         T1 = (Xl - Xo) / Xd
	//         T2 = (Xh - Xo) / Xd
	//         If T1 > T2 swap (T1, T2) /* since T1 intersection with near plane */
	//         If T1 > Tnear set Tnear =T1 /* want largest Tnear */
	//         If T2 < Tfar set Tfar="T2" /* want smallest Tfar */
	//         If Tnear > Tfar box is missed so
	//             return false
	//         If Tfar < 0 box is behind ray
	//             return false
	//     end
	// end of for loop
	float Tnear, Tfar;
	Tnear = -FLT_MAX;
	Tfar = FLT_MAX;
	float2 limits;
	// box intersection routine
#define CHECK_NEAR_AND_FAR_INTERSECTION(c)							    \
    if (rayInWorldSpace.##c == 0.f) {						    \
	if (originInWorldSpace.##c < limits.x) return false;					    \
	if (originInWorldSpace.##c > limits.y) return false;					    \
	} else {											    \
	float T1 = (limits.x - originInWorldSpace.##c)/rayInWorldSpace.##c;			    \
	float T2 = (limits.y - originInWorldSpace.##c)/rayInWorldSpace.##c;			    \
	if (T1>T2) { float tmp=T1; T1=T2; T2=tmp; }						    \
	if (T1 > Tnear) Tnear = T1;								    \
	if (T2 < Tfar)  Tfar = T2;								    \
	if (Tnear > Tfar)	return false;									    \
	if (Tfar < 0.f)	return false;									    \
	limits = tex1Dfetch(g_pCFBVHlimitsTexture, 3 * boxIdx); // box.bottom._x/top._x placed in limits.x/limits.y
															//limits = make_float2(cudaBVHlimits[6 * boxIdx + 0], cudaBVHlimits[6 * boxIdx + 1]);
	CHECK_NEAR_AND_FAR_INTERSECTION(x)
		limits = tex1Dfetch(g_pCFBVHlimitsTexture, 3 * boxIdx + 1); // box.bottom._y/top._y placed in limits.x/limits.y
																	//limits = make_float2(cudaBVHlimits[6 * boxIdx + 2], cudaBVHlimits[6 * boxIdx + 3]);
	CHECK_NEAR_AND_FAR_INTERSECTION(y)
		limits = tex1Dfetch(g_pCFBVHlimitsTexture, 3 * boxIdx + 2); // box.bottom._z/top._z placed in limits.x/limits.y
																	//limits = make_float2(cudaBVHlimits[6 * boxIdx + 4], cudaBVHlimits[6 * boxIdx + 5]);
	CHECK_NEAR_AND_FAR_INTERSECTION(z)
		// If Box survived all above tests, return true with intersection point Tnear and exit point Tfar.
		return true;
//	BVH intersection routine	//
//	using CUDA texture memory	//
// there are 3 forms of the BVH: a "pure" BVH, a cache-friendly BVH (taking up less memory space than the pure BVH)
// and a "textured" BVH which stores its data in CUDA texture memory (which is cached). The last one is gives the
// best performance and is used here.
__device__ bool BVH_IntersectTriangles(
	int* cudaBVHindexesOrTrilists, const Vector3Df& origin, const Vector3Df& ray, unsigned avoidSelf,
	int& pBestTriIdx, Vector3Df& pointHitInWorldSpace, float& kAB, float& kBC, float& kCA, float& hitdist,
	float* cudaBVHlimits, float* cudaTriangleIntersectionData, int* cudaTriIdxList, Vector3Df& boxnormal)
	// in the loop below, maintain the closest triangle and the point where we hit it:
	pBestTriIdx = -1;
	float bestTriDist;
	// start from infinity
	bestTriDist = FLT_MAX;
	// create a stack for each ray
	// the stack is just a fixed size array of indices to BVH nodes
	int stack[BVH_STACK_SIZE];
	int stackIdx = 0;
	stack[stackIdx++] = 0;
	Vector3Df hitpoint;
	// while the stack is not empty
	while (stackIdx) {
		// pop a BVH node (or AABB, Axis Aligned Bounding Box) from the stack
		int boxIdx = stack[stackIdx - 1];
		//uint* pCurrent = &cudaBVHindexesOrTrilists[boxIdx];
		// decrement the stackindex
		stackIdx--;
		// fetch the data (indices to childnodes or index in triangle list + trianglecount) associated with this node
		uint4 data = tex1Dfetch(g_pCFBVHindexesOrTrilistsTexture, boxIdx);
		// original, "pure" BVH form...
		//if (!pCurrent->IsLeaf()) {
		// cache-friendly BVH form...
		//if (!(cudaBVHindexesOrTrilists[4 * boxIdx + 0] & 0x80000000)) { // INNER NODE
		// texture memory BVH form...
		// determine if BVH node is an inner node or a leaf node by checking the highest bit (bitwise AND operation)
		// inner node if highest bit is 1, leaf node if 0
		if (!(data.x & 0x80000000)) {   // INNER NODE
										// if ray intersects inner node, push indices of left and right child nodes on the stack
			if (RayIntersectsBox(origin, ray, boxIdx)) {
				//stack[stackIdx++] = pCurrent->u.inner._idxRight;
				//stack[stackIdx++] = cudaBVHindexesOrTrilists[4 * boxIdx + 1];
				stack[stackIdx++] = data.y; // right child node index
											//stack[stackIdx++] = pCurrent->u.inner._idxLeft;
											//stack[stackIdx++] = cudaBVHindexesOrTrilists[4 * boxIdx + 2];
				stack[stackIdx++] = data.z; // left child node index
											// return if stack size is exceeded
				if (stackIdx>BVH_STACK_SIZE)
					return false;
		else { // LEAF NODE
			   // BVHLeaf *p = dynamic_cast<BVHLeaf*>(pCurrent);
			   // for(std::list<const Triangle*>::iterator it=p->_triangles.begin();
			   //    it != p->_triangles.end();
			   //    it++)
			   // for(unsigned i=pCurrent->u.leaf._startIndexInTriIndexList;
			   //    i<pCurrent->u.leaf._startIndexInTriIndexList + (pCurrent->u.leaf._count & 0x7fffffff);
			   // for (unsigned i = cudaBVHindexesOrTrilists[4 * boxIdx + 3]; i< cudaBVHindexesOrTrilists[4 * boxIdx + 3] + (cudaBVHindexesOrTrilists[4 * boxIdx + 0] & 0x7fffffff); i++) { // data.w = number of triangles in leaf
			   // loop over every triangle in the leaf node
			   // data.w is start index in triangle list
			   // data.x stores number of triangles in leafnode (the bitwise AND operation extracts the triangle number)
			for (unsigned i = data.w; i < data.w + (data.x & 0x7fffffff); i++) {
				//const Triangle& triangle = *(*it);
				//const Triangle& triangle = pTriangles[cudaTriIdxList[i]];
				// fetch the index of the current triangle
				int idx = tex1Dfetch(g_triIdxListTexture, i).x;
				//int idx = cudaTriIdxList[i];
				// check if triangle is the same as the one intersected by previous ray
				// to avoid self-reflections/refractions
				if (avoidSelf == idx)
					continue;
				// fetch triangle center and normal from texture memory
				float4 center = tex1Dfetch(g_trianglesTexture, 5 * idx);
				float4 normal = tex1Dfetch(g_trianglesTexture, 5 * idx + 1);
				// use the pre-computed triangle intersection data: normal, d, e1/d1, e2/d2, e3/d3
				float k = dot(normal, ray);
				if (k == 0.0f)
					continue; // this triangle is parallel to the ray, ignore it.
				float s = (normal.w - dot(normal, origin)) / k;
				if (s <= 0.0f) // this triangle is "behind" the origin.
					continue;
				if (s <= NUDGE_FACTOR)  // epsilon
					continue;
				Vector3Df hit = ray * s;
				hit += origin;
				// ray triangle intersection
				// Is the intersection of the ray with the triangle's plane INSIDE the triangle?
				float4 ee1 = tex1Dfetch(g_trianglesTexture, 5 * idx + 2);
				//float4 ee1 = make_float4(cudaTriangleIntersectionData[20 * idx + 8], cudaTriangleIntersectionData[20 * idx + 9], cudaTriangleIntersectionData[20 * idx + 10], cudaTriangleIntersectionData[20 * idx + 11]);
				float kt1 = dot(ee1, hit) - ee1.w;
				if (kt1<0.0f) continue;
				float4 ee2 = tex1Dfetch(g_trianglesTexture, 5 * idx + 3);
				//float4 ee2 = make_float4(cudaTriangleIntersectionData[20 * idx + 12], cudaTriangleIntersectionData[20 * idx + 13], cudaTriangleIntersectionData[20 * idx + 14], cudaTriangleIntersectionData[20 * idx + 15]);
				float kt2 = dot(ee2, hit) - ee2.w;
				if (kt2<0.0f) continue;
				float4 ee3 = tex1Dfetch(g_trianglesTexture, 5 * idx + 4);
				//float4 ee3 = make_float4(cudaTriangleIntersectionData[20 * idx + 16], cudaTriangleIntersectionData[20 * idx + 17], cudaTriangleIntersectionData[20 * idx + 18], cudaTriangleIntersectionData[20 * idx + 19]);
				float kt3 = dot(ee3, hit) - ee3.w;
				if (kt3<0.0f) continue;
				// ray intersects triangle, "hit" is the world space coordinate of the intersection.
					// is this intersection closer than all the others?
					float hitZ = distancesq(origin, hit);
					if (hitZ < bestTriDist) {
						// maintain the closest hit
						bestTriDist = hitZ;
						hitdist = sqrtf(bestTriDist);
						pBestTriIdx = idx;
						pointHitInWorldSpace = hit;
						// store barycentric coordinates (for texturing, not used for now)
						kAB = kt1;
						kBC = kt2;
						kCA = kt3;
	return pBestTriIdx != -1;
// PATH TRACING
__device__ Vector3Df path_trace(curandState *randstate, Vector3Df originInWorldSpace, Vector3Df rayInWorldSpace, int avoidSelf,
	Triangle *pTriangles, int* cudaBVHindexesOrTrilists, float* cudaBVHlimits, float* cudaTriangleIntersectionData, int* cudaTriIdxList)
	// colour mask
	Vector3Df mask = Vector3Df(1.0f, 1.0f, 1.0f);
	// accumulated colour
	Vector3Df accucolor = Vector3Df(0.0f, 0.0f, 0.0f);
	for (int bounces = 0; bounces < 5; bounces++) {  // iteration up to 4 bounces (instead of recursion in CPU code)
		int sphere_id = -1;
		int triangle_id = -1;
		int pBestTriIdx = -1;
		int geomtype = -1;
		const Triangle *pBestTri = NULL;
		Vector3Df pointHitInWorldSpace;
		float kAB = 0.f, kBC = 0.f, kCA = 0.f; // distances from the 3 edges of the triangle (from where we hit it), to be used for texturing
		float tmin = 1e20;
		float tmax = -1e20;
		float d = 1e20;
		float scene_t = 1e20;
		float inf = 1e20;
		float hitdistance = 1e20;
		Vector3Df f = Vector3Df(0, 0, 0);
		Vector3Df emit = Vector3Df(0, 0, 0);
		Vector3Df x; // intersection point
		Vector3Df n; // normal
		Vector3Df nl; // oriented normal
		Vector3Df boxnormal = Vector3Df(0, 0, 0);
		Vector3Df dw; // ray direction of next path segment
		Refl_t refltype;
		float3 rayorig = make_float3(originInWorldSpace.x, originInWorldSpace.y, originInWorldSpace.z);
		float3 raydir = make_float3(rayInWorldSpace.x, rayInWorldSpace.y, rayInWorldSpace.z);
		// intersect all triangles in the scene stored in BVH
			cudaBVHindexesOrTrilists, originInWorldSpace, rayInWorldSpace, avoidSelf,
			pBestTriIdx, pointHitInWorldSpace, kAB, kBC, kCA, hitdistance, cudaBVHlimits,
			cudaTriangleIntersectionData, cudaTriIdxList, boxnormal);
		// intersect all spheres in the scene
		float numspheres = sizeof(spheres) / sizeof(Sphere);
		for (int i = int(numspheres); i--;) {  // for all spheres in scene
											   // keep track of distance from origin to closest intersection point
			if ((d = spheres[i].intersect(Ray(rayorig, raydir))) && d < scene_t) { scene_t = d; sphere_id = i; geomtype = 1; }
		// set avoidSelf to current triangle index to avoid intersection between this triangle and the next ray,
		// so that we don't get self-shadow or self-reflection from this triangle...
		avoidSelf = pBestTriIdx;
		if (hitdistance < scene_t && hitdistance > 0.002) // EPSILON
			scene_t = hitdistance;
			triangle_id = pBestTriIdx;
			geomtype = 2;
		if (scene_t > 1e20) return Vector3Df(0.0f, 0.0f, 0.0f);
		// SPHERES:
		if (geomtype == 1) {
			Sphere &sphere = spheres[sphere_id]; // hit object with closest intersection
			x = originInWorldSpace + rayInWorldSpace * scene_t;  // intersection point on object
			n = Vector3Df(x.x - sphere.pos.x, x.y - sphere.pos.y, x.z - sphere.pos.z);		// normal
			n.normalize();
			nl = dot(n, rayInWorldSpace) < 0 ? n : n * -1; // correctly oriented normal
			f = Vector3Df(sphere.col.x, sphere.col.y, sphere.col.z);   // object colour
			refltype = sphere.refl;
			emit = Vector3Df(sphere.emi.x, sphere.emi.y, sphere.emi.z);  // object emission
			accucolor += (mask * emit);
		// TRIANGLES:5
		if (geomtype == 2) {
			pBestTri = &pTriangles[triangle_id];
			x = pointHitInWorldSpace;  // intersection point
			n = pBestTri->_normal;  // normal
									//n = Vector3Df(0,0,1);
			n.normalize();
			Vector3Df colour = Vector3Df(0.9f, 0.3f, 0.0f); // hardcoded triangle colour
															//Vector3Df colour = pBestTri->_colorf;
			refltype = COAT;
			f = colour;
			emit = Vector3Df(0, 0, 0);  // object emission
		// basic material system, all parameters are hard-coded (such as phong exponent, index of refraction)
		// diffuse material, based on smallpt by Kevin Beason
		if (refltype == DIFF) {
			// pick two random numbers
			float phi = 2 * M_PI * curand_uniform(randstate);
			float r2 = curand_uniform(randstate);
			float r2s = sqrtf(r2);
			// compute orthonormal coordinate frame uvw with hitpoint as origin
			Vector3Df w = nl; w.normalize();
			Vector3Df u = cross((fabs(w.x) > .1 ? Vector3Df(0, 1, 0) : Vector3Df(1, 0, 0)), w); u.normalize();
			Vector3Df v = cross(w, u);
			// compute cosine weighted random ray direction on hemisphere
			dw = u*cosf(phi)*r2s + v*sinf(phi)*r2s + w*sqrtf(1 - r2);
			dw.normalize();
			// offset origin next path segment to prevent self intersection
			pointHitInWorldSpace = x + w * 0.01;  // scene size dependent
												  // multiply mask with colour of object
			mask *= f;
		// Phong metal material from "Realistic Ray Tracing", P. Shirley
		if (refltype == METAL) {
			// compute random perturbation of ideal reflection vector
			// the higher the phong exponent, the closer the perturbed vector is to the ideal reflection direction
			float phongexponent = 20;
			float cosTheta = powf(1 - r2, 1.0f / (phongexponent + 1));
			float sinTheta = sqrtf(1 - cosTheta * cosTheta);
			// create orthonormal basis uvw around reflection vector with hitpoint as origin
			// w is ray direction for ideal reflection
			Vector3Df w = rayInWorldSpace - n * 2.0f * dot(n, rayInWorldSpace); w.normalize();
			Vector3Df v = cross(w, u); // v is normalised by default
			dw = u * cosf(phi) * sinTheta + v * sinf(phi) * sinTheta + w * cosTheta;
			dw.normalize();
			mask *= f;
		// specular material (perfect mirror)
		if (refltype == SPEC) {
			// compute reflected ray direction according to Snell's law
			dw = rayInWorldSpace - n * 2.0f * dot(n, rayInWorldSpace);
			pointHitInWorldSpace = x + nl * 0.01;   // scene size dependent
			mask *= f;
		// COAT material based on https://github.com/peterkutz/GPUPathTracer
		// randomly select diffuse or specular reflection
		// looks okay-ish but inaccurate (no Fresnel calculation yet)
		if (refltype == COAT) {
			float rouletteRandomFloat = curand_uniform(randstate);
			float threshold = 0.05f;
			Vector3Df specularColor = Vector3Df(1, 1, 1);  // hard-coded
			bool reflectFromSurface = (rouletteRandomFloat < threshold); //computeFresnel(make_Vector3Df(n.x, n.y, n.z), incident, incidentIOR, transmittedIOR, reflectionDirection, transmissionDirection).reflectionCoefficient);
			if (reflectFromSurface) { // calculate perfectly specular reflection
									  // Ray reflected from the surface. Trace a ray in the reflection direction.
									  // TODO: Use Russian roulette instead of simple multipliers! (Selecting between diffuse sample and no sample (absorption) in this case.)
				mask *= specularColor;
			else {  // calculate perfectly diffuse reflection
				float r1 = 2 * M_PI * curand_uniform(randstate);
				dw = u*cosf(r1)*r2s + v*sinf(r1)*r2s + w*sqrtf(1 - r2);
				dw.normalize();
				pointHitInWorldSpace = x + nl * 0.01;  // // scene size dependent
				mask *= f;
				//mask *= make_Vector3Df(0.15f, 0.15f, 0.15f);  // gold metal
		} // end COAT
		  // perfectly refractive material (glass, water)
		if (refltype == REFR) {
			bool into = dot(n, nl) > 0; // is ray entering or leaving refractive material?
			float nc = 1.0f;  // Index of Refraction air
			float nt = 1.5f;  // Index of Refraction glass/water
			float nnt = into ? nc / nt : nt / nc;  // IOR ratio of refractive materials
			float ddn = dot(rayInWorldSpace, nl);
			float cos2t = 1.0f - nnt*nnt * (1.f - ddn*ddn);
			if (cos2t < 0.0f) // total internal reflection
				dw = rayInWorldSpace;
				dw -= n * 2.0f * dot(n, rayInWorldSpace);
			else // cos2t > 0
				// compute direction of transmission ray
				Vector3Df tdir = rayInWorldSpace * nnt;
				tdir -= n * ((into ? 1 : -1) * (ddn*nnt + sqrtf(cos2t)));
				tdir.normalize();
				float R0 = (nt - nc)*(nt - nc) / (nt + nc)*(nt + nc);
				float c = 1.f - (into ? -ddn : dot(tdir, n));
				float Re = R0 + (1.f - R0) * c * c * c * c * c;
				float Tr = 1 - Re; // Transmission
				float P = .25f + .5f * Re;
				float RP = Re / P;
				float TP = Tr / (1.f - P);
				// randomly choose reflection or transmission ray
				if (curand_uniform(randstate) < 0.25) // reflection ray
					mask *= RP;
				else // transmission ray
					mask *= TP;
					dw = tdir; //r = Ray(x, tdir);
					pointHitInWorldSpace = x + nl * 0.001f; // epsilon must be small to avoid artefacts
		// set up origin and direction of next path segment
		originInWorldSpace = pointHitInWorldSpace;
		rayInWorldSpace = dw;
	return Vector3Df(accucolor.x, accucolor.y, accucolor.z);
union Colour  // 4 bytes = 4 chars = 1 float
	float c;
	uchar4 components;
// the core path tracing kernel,
// running in parallel for all pixels
__global__ void CoreLoopPathTracingKernel(Vector3Df* output, Vector3Df* accumbuffer, Triangle* pTriangles, Camera* cudaRendercam,
	int* cudaTriIdxList, unsigned int framenumber, unsigned int hashedframenumber)
	// assign a CUDA thread to every pixel by using the threadIndex
	unsigned int x = blockIdx.x*blockDim.x + threadIdx.x;
	unsigned int y = blockIdx.y*blockDim.y + threadIdx.y;
	// global threadId, see richiesams blogspot
	int threadId = (blockIdx.x + blockIdx.y * gridDim.x) * (blockDim.x * blockDim.y) + (threadIdx.y * blockDim.x) + threadIdx.x;
	// create random number generator and initialise with hashed frame number, see RichieSams blogspot
	curandState randState; // state of the random number generator, to prevent repetition
	curand_init(hashedframenumber + threadId, 0, 0, &randState);
	Vector3Df finalcol; // final pixel colour
	Vector3Df rendercampos = Vector3Df(cudaRendercam->position.x, cudaRendercam->position.y, cudaRendercam->position.z);
	int i = (height - y - 1)*width + x; // pixel index in buffer
	int pixelx = x; // pixel x-coordinate on screen
	int pixely = height - y - 1; // pixel y-coordintate on screen
	finalcol = Vector3Df(0.0f, 0.0f, 0.0f); // reset colour to zero for every pixel
	for (int s = 0; s < samps; s++) {
		// compute primary ray direction
		// use camera view of current frame (transformed on CPU side) to create local orthonormal basis
		Vector3Df rendercamview = Vector3Df(cudaRendercam->view.x, cudaRendercam->view.y, cudaRendercam->view.z); rendercamview.normalize(); // view is already supposed to be normalized, but normalize it explicitly just in case.
		Vector3Df rendercamup = Vector3Df(cudaRendercam->up.x, cudaRendercam->up.y, cudaRendercam->up.z); rendercamup.normalize();
		Vector3Df horizontalAxis = cross(rendercamview, rendercamup); horizontalAxis.normalize(); // Important to normalize!
		Vector3Df verticalAxis = cross(horizontalAxis, rendercamview); verticalAxis.normalize(); // verticalAxis is normalized by default, but normalize it explicitly just for good measure.
		Vector3Df middle = rendercampos + rendercamview;
		Vector3Df horizontal = horizontalAxis * tanf(cudaRendercam->fov.x * 0.5 * (M_PI / 180)); // Now treating FOV as the full FOV, not half, so I multiplied it by 0.5. I also normzlized A and B, so there's no need to divide by the length of A or B anymore. Also normalized view and removed lengthOfView. Also removed the cast to float.
		Vector3Df vertical = verticalAxis * tanf(-cudaRendercam->fov.y * 0.5 * (M_PI / 180)); // Now treating FOV as the full FOV, not half, so I multiplied it by 0.5. I also normzlized A and B, so there's no need to divide by the length of A or B anymore. Also normalized view and removed lengthOfView. Also removed the cast to float.
																							  // anti-aliasing
																							  // calculate center of current pixel and add random number in X and Y dimension
																							  // based on https://github.com/peterkutz/GPUPathTracer
		float jitterValueX = curand_uniform(&randState) - 0.5;
		float jitterValueY = curand_uniform(&randState) - 0.5;
		float sx = (jitterValueX + pixelx) / (cudaRendercam->resolution.x - 1);
		float sy = (jitterValueY + pixely) / (cudaRendercam->resolution.y - 1);
		// compute pixel on screen
		Vector3Df pointOnPlaneOneUnitAwayFromEye = middle + (horizontal * ((2 * sx) - 1)) + (vertical * ((2 * sy) - 1));
		Vector3Df pointOnImagePlane = rendercampos + ((pointOnPlaneOneUnitAwayFromEye - rendercampos) * cudaRendercam->focalDistance); // Important for depth of field!
																																	   // calculation of depth of field / camera aperture
		Vector3Df aperturePoint;
		if (cudaRendercam->apertureRadius > 0.00001) { // the small number is an epsilon value.
													   // generate random numbers for sampling a point on the aperture
			float random1 = curand_uniform(&randState);
			float random2 = curand_uniform(&randState);
			// randomly pick a point on the circular aperture
			float angle = TWO_PI * random1;
			float distance = cudaRendercam->apertureRadius * sqrtf(random2);
			float apertureX = cos(angle) * distance;
			float apertureY = sin(angle) * distance;
			aperturePoint = rendercampos + (horizontalAxis * apertureX) + (verticalAxis * apertureY);
		else { // zero aperture
			aperturePoint = rendercampos;
		// calculate ray direction of next ray in path
		Vector3Df apertureToImagePlane = pointOnImagePlane - aperturePoint;
		apertureToImagePlane.normalize(); // ray direction, needs to be normalised
		Vector3Df rayInWorldSpace = apertureToImagePlane;
		// in theory, this should not be required
		rayInWorldSpace.normalize();
		// origin of next ray in path
		Vector3Df originInWorldSpace = aperturePoint;
		finalcol += path_trace(&randState, originInWorldSpace, rayInWorldSpace, -1, pTriangles,
			cudaBVHindexesOrTrilists, cudaBVHlimits, cudaTriangleIntersectionData, cudaTriIdxList) * (1.0f / samps);
	// add pixel colour to accumulation buffer (accumulates all samples)
	accumbuffer[i] += finalcol;
	// averaged colour: divide colour by the number of calculated frames so far
	Vector3Df tempcol = accumbuffer[i] / framenumber;
	Colour fcolour;
	Vector3Df colour = Vector3Df(clamp(tempcol.x, 0.0f, 1.0f), clamp(tempcol.y, 0.0f, 1.0f), clamp(tempcol.z, 0.0f, 1.0f));
	// convert from 96-bit to 24-bit colour + perform gamma correction
	fcolour.components = make_uchar4((unsigned char)(powf(colour.x, 1 / 2.2f) * 255), (unsigned char)(powf(colour.y, 1 / 2.2f) * 255), (unsigned char)(powf(colour.z, 1 / 2.2f) * 255), 1);
	// store pixel coordinates and pixelcolour in OpenGL readable outputbuffer
	output[i] = Vector3Df(x, y, fcolour.c);
bool g_bFirstTime = true;
// the gateway to CUDA, called from C++ (in void disp() in main.cpp)
void cudarender(Vector3Df* dptr, Vector3Df* accumulatebuffer, Triangle* cudaTriangles, int* cudaBVHindexesOrTrilists,
	unsigned framenumber, unsigned hashedframes, Camera* cudaRendercam) {
	if (g_bFirstTime) {
		// if this is the first time cudarender() is called,
		// bind the scene data to CUDA textures!
		g_bFirstTime = false;
		printf("g_triIndexListNo: %d\n", g_triIndexListNo);
		printf("g_pCFBVH_No: %d\n", g_pCFBVH_No);
		printf("g_verticesNo: %d\n", g_verticesNo);
		printf("g_trianglesNo: %d\n", g_trianglesNo);
		cudaChannelFormatDesc channel1desc = cudaCreateChannelDesc<uint1>();
		cudaBindTexture(NULL, &g_triIdxListTexture, cudaTriIdxList, &channel1desc, g_triIndexListNo * sizeof(uint1));
		cudaChannelFormatDesc channel2desc = cudaCreateChannelDesc<float2>();
		cudaBindTexture(NULL, &g_pCFBVHlimitsTexture, cudaBVHlimits, &channel2desc, g_pCFBVH_No * 6 * sizeof(float));
		cudaChannelFormatDesc channel3desc = cudaCreateChannelDesc<uint4>();
		cudaBindTexture(NULL, &g_pCFBVHindexesOrTrilistsTexture, cudaBVHindexesOrTrilists, &channel3desc,
			g_pCFBVH_No * sizeof(uint4));
		//cudaChannelFormatDesc channel4desc = cudaCreateChannelDesc<float4>();
		//cudaBindTexture(NULL, &g_verticesTexture, cudaPtrVertices, &channel4desc, g_verticesNo * 8 * sizeof(float));
		cudaChannelFormatDesc channel5desc = cudaCreateChannelDesc<float4>();
		cudaBindTexture(NULL, &g_trianglesTexture, cudaTriangleIntersectionData, &channel5desc, g_trianglesNo * 20 * sizeof(float));
	dim3 block(16, 16, 1);   // dim3 CUDA specific syntax, block and grid are required to schedule CUDA threads over streaming multiprocessors
	dim3 grid(width / block.x, height / block.y, 1);
	// Configure grid and block sizes:
	int threadsPerBlock = 256;
	// Compute the number of blocks required, performing a ceiling operation to make sure there are enough:
	int fullBlocksPerGrid = ((width * height) + threadsPerBlock - 1) / threadsPerBlock;
	// <<<fullBlocksPerGrid, threadsPerBlock>>>
	CoreLoopPathTracingKernel << <grid, block >> >(dptr, accumulatebuffer, cudaTriangles, cudaRendercam, cudaBVHindexesOrTrilists,
		cudaBVHlimits, cudaTriangleIntersectionData, cudaTriIdxList, framenumber, hashedframes);
