I am currently using Jetpack 5.1.2 and installed torch through torch-2.1.0a0+41361538.nv23.06-cp38-cp38-linux_aarch64.whl.(PyTorch for Jetson)
However, when I try to run the gemma2 model, I get the following error:
AttributeError: module ‘torch._dynamo’ has no attribute ‘mark_static_address’
The known solution to this error is to upgrade torch, but if I upgrade torch, I cannot use CUDA with torch. I am not sure what to do. Please help.
Also, are there any plans to support official 2.1 rather than the alpha version of Torch 2.1 in 5.1.2?
Do you need the JetPack 5 environment?
If not, you can upgrade to JetPack 6 which has PyTorch v2.1 prebuilt package already.
We won’t provide further packages for JetPack 5 since we now focus more on the latest JetPack 6.0.
You can still build v2.1 from the source and the steps can be found in the below topic.
