[ERROR] Wrong input name specified in -p, please double check
I am using Jetson Nano 2GB, Jetpack 4.6, DS 6.0.
I am trying to generate the engine of facial landmarks and run it on deepstream.
This is the command I am using:
./tao-converter /home/user/Downloads/deepstream_tao_apps/models/faciallandmark/faciallandmarks.etlt -k nvidia_tlt -p input_face_images:0,1x1x80x80,4x1x80x80,16x1x80x80 -e ./model.plan -t fp16
[INFO] [MemUsageChange] Init CUDA: CPU +230, GPU +3, now: CPU 248, GPU 1924 (MiB)
[INFO] [MemUsageSnapshot] Begin constructing builder kernel library: CPU 248 MiB, GPU 1918 MiB
[INFO] [MemUsageSnapshot] End constructing builder kernel library: CPU 277 MiB, GPU 1921 MiB
[INFO] ----------------------------------------------------------------
[INFO] Input filename: /tmp/filegGPaFQ
[INFO] ONNX IR version: 0.0.5
[INFO] Opset version: 10
[INFO] Producer name: keras2onnx
[INFO] Producer version: 1.8.1
[INFO] Domain: onnxmltools
[INFO] Model version: 0
[INFO] Doc string:
[WARNING] onnx2trt_utils.cpp:366: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[WARNING] onnx2trt_utils.cpp:392: One or more weights outside the range of INT32 was clamped
[ERROR] Wrong input name specified in -p, please double check.
Aborted (core dumped)
I am not able to generate the model.plan to deploy it on DS 6.0.
Please I need help on this manner.
Please refer to deepstream_tao_apps/apps/tao_others/deepstream-faciallandmark-app at master · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub instead.
Hi Morganh. I am using the Python version not the C++. How can I convert the engine to be able to use it in the python deepstream test1-usbcam?
You can refer to How to do inference with fpenet_fp32.trt - #11 by Morganh and Cannot infer with fpenet with TensorRT8.0 - #14 by Morganh
