ERRORINVALID_ARGUMENT: Cannot find binding of given name
Description
I am converting an .onnx model to a TensorRT format on google colab using the command:
!./makeCudaEngine -i ../../ScaledYOLOv4/yolov4-p5.onnx -o yolov4-p5.trt
the command does save a yolov4-p5.trt but with the following output
ERRORINVALID_ARGUMENT: Cannot find binding of given name: conf
ERRORINVALID_ARGUMENT: Cannot find binding of given name: cls
ERRORINVALID_ARGUMENT: Cannot find binding of given name: bbox
save yolov4-p5.trt
Environment
Google Colab
Copyright (c) 2005-2020 NVIDIA Corporation
Built on Mon_Oct_12_20:09:46_PDT_2020
Cuda compilation tools, release 11.1, V11.1.105
Build cuda_11.1.TC455_06.29190527_0
Ubuntu 18.04.5 LTS \n \l
How can I fix this? Thanks!
Hi @jcdulo ,
Can you please share your onnx model and reproducible script, so that we can try the same at our end.
Thank you for replying @AakankshaS.
I am following the steps in this repository:
https://github.com/talebolano/TensorRT-Scaled-YOLOv4
The error comes up at step 3. Convert onnx model to try model
./makeCudaEngine -i ../../ScaledYOLOv4/yolov4-csp.onnx -o yolov4-csp.trt
and affects even step 4.Test
I am including a link to my google colab as well for your review.
Google Colab Notebook
Thank you.
Hi @jcdulo,
Sorry for the delayed response. We are unable to run google colab notebook successfully.
We request you to please share ONNX model to try from our end.
Meanwhile you can also try trtexec to convert ONNX model to trt.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
For your reference,
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
Thank you.
