Hi I am new with using Jetson products and I want to know how I can flash my Jetson TX2 device but I keep getting some strange errors.
5:32:55 ERROR: Flash Jetson TX2 - flash: File "/home/user/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py", line 1296, in
15:32:55 ERROR: Flash Jetson TX2 - flash: tegraflash_run_commands()
15:32:55 ERROR: Flash Jetson TX2 - flash: File "/home/user/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py", line 1155, in tegraflash_run_commands
15:32:55 ERROR: Flash Jetson TX2 - flash: interpreter.onecmd(command)
15:32:55 ERROR: Flash Jetson TX2 - flash: File "/usr/lib/python3.5/cmd.py", line 217, in onecmd
15:32:55 ERROR: Flash Jetson TX2 - flash: return func(arg)
15:32:55 ERROR: Flash Jetson TX2 - flash: File "/home/user/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py", line 785, in do_dump
15:32:55 ERROR: Flash Jetson TX2 - flash: tegraflash_dump(exports, args)
15:32:55 ERROR: Flash Jetson TX2 - flash: File "/home/user/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py", line 1375, in tegraflash_dump
15:32:55 ERROR: Flash Jetson TX2 - flash: tegraflash_dumpeeprom(args, dump_args[1:])
15:32:55 ERROR: Flash Jetson TX2 - flash: File "/home/user/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py", line 1453, in tegraflash_dumpeeprom
15:32:55 ERROR: Flash Jetson TX2 - flash: run_command(command)
15:32:55 ERROR: Flash Jetson TX2 - flash: File "/home/user/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py", line 202, in run_command
15:32:55 ERROR: Flash Jetson TX2 - flash: log = print_process(process, enable_print)
15:32:55 ERROR: Flash Jetson TX2 - flash: File "/home/user/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash_internal.py", line 178, in print_process
15:32:55 ERROR: Flash Jetson TX2 - flash: for string in process.communicate()[0].decode('utf-8').split('\n'):
15:32:55 ERROR: Flash Jetson TX2 - flash: UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa4 in position 17: invalid start byte
15:32:55 ERROR: Flash Jetson TX2 - flash: --- Error: Reading board information failed.
15:32:55 INFO: Flash Jetson TX2 - flash: [ Component Install Finished with Error ]
15:32:55 INFO: Flash Jetson TX2 - flash: [host] [ 5.70 MB released. Disk Avail: 58.49 GB ]
15:32:55 INFO: Flash Jetson TX2 - flash: [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 9s ]
15:32:55 ERROR: Flash Jetson TX2 - flash: command terminated with error
15:32:55 SUMMARY: Flash Jetson TX2 - flash: First Error: Installation failed.
Here is the summary:
15:26:46 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
15:31:46 SUMMARY: File System and OS - target_image: Install completed successfully.
15:32:55 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
15:32:55 SUMMARY: Multimedia API - target: Depends on failed component
15:32:55 SUMMARY: TensorRT on Target - target: Depends on failed component
15:32:55 SUMMARY: VisionWorks on Target - target: Depends on failed component
15:32:55 SUMMARY: VPI on Target - target: Depends on failed component
15:32:55 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
15:32:55 SUMMARY: cuDNN on Target - target: Depends on failed component
15:32:55 SUMMARY: OpenCV on Target - target: Depends on failed component
15:32:55 SUMMARY: Nsight Systems CLI - target: Depends on failed component
15:32:55 SUMMARY: DateTime Target Setup - target: Depends on failed component
