Several of the CUDA samples installed by Jetpack 3.0 fail to build with R27.1 on the Jetson TX2, including smokeParticles and nbody. Any idea what could be going wrong here?
nvidia@trixie:~/NVIDIA_CUDA-8.0_Samples/5_Simulations/smokeParticles$ make
/usr/local/cuda-8.0/bin/nvcc -ccbin g++ -I…/…/common/inc -m64 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_62,code=compute_62 -o GLSLProgram.o -c GLSLProgram.cpp
GLSLProgram.cpp: In member function ‘void GLSLProgram::bindTexture(const char*, GLuint, GLenum, GLint)’:
GLSLProgram.cpp:173:9: error: reference to ‘glActiveTexture’ is ambiguous
glActiveTexture(GL_TEXTURE0 + unit);
In file included from …/…/common/inc/helper_gl.h:23:0,
from GLSLProgram.cpp:14:
/usr/include/GL/gl.h:1823:23: note: candidates are: void glActiveTexture(GLenum)
GLAPI void GLAPIENTRY glActiveTexture( GLenum texture );
In file included from GLSLProgram.cpp:14:0:
…/…/common/inc/helper_gl.h:106:17: note: void (* __HelperGL::glActiveTexture)(GLenum)
USE_GL_FUNC(glActiveTexture, PFNGLACTIVETEXTUREPROC);
…/…/common/inc/helper_gl.h:47:51: note: in definition of macro ‘USE_GL_FUNC’
#define USE_GL_FUNC(name, proto) extern proto name
GLSLProgram.cpp:177:9: error: reference to ‘glActiveTexture’ is ambiguous
glActiveTexture(GL_TEXTURE0);
Makefile:268: recipe for target ‘GLSLProgram.o’ failed
make: *** [GLSLProgram.o] Error 1
