Errors cross compiler in QT with NVCC
Hi, I need some directions for my problem. I need to cross compile some CUDA code in QT. So probably my problem is with NVCC compiler. My host is Ubuntu 18.04 and device where I want to run it is Jetson. This is how my gst_dde.pro file looks like:
QT -=  gui
TARGET = gst_dde
TEMPLATE = lib
CONFIG += plugin c++11
CONFIG += link_pkgconfig
PKGCONFIG += opencv \
             cuda-8.0 \
             gstreamer-video-1.0
DEFINES += QT_DEPRECATED_WARNINGS
SOURCES +=  main.cpp
HEADERS += gst_dde_global.h \
    gst_dde.cuh
QMAKE_EXTRA_COMPILERS += cuda
CUDA_SOURCES += gst_dde.cu
CUDA_DIR = /usr/local/cuda
CUDA_ARCH = sm_62
INCLUDEPATH += $$CUDA_DIR/include
LIBS += -L $$CUDA_DIR/lib64 -lcudart -lcuda
cuda.commands = $$CUDA_DIR/bin/nvcc -c -arch=$$CUDA_ARCH -o ${QMAKE_FILE_OUT} ${QMAKE_FILE_NAME}
cuda.dependency_type = TYPE_C
cuda.depend_command = $$CUDA_DIR/bin/nvcc -M ${QMAKE_FILE_NAME}
cuda.input = CUDA_SOURCES
cuda.output = ${OBJECTS_DIR}${QMAKE_FILE_BASE}_cuda.o
unix {
    target.path = vlatacom/vsp/gstreamer_plugins
    INSTALLS += target
QMAKE_RPATHDIR +=   $$(ORIGIN).
DISTFILES += gst_dde.cu
gst_dde.cuh looks like:
#ifndef GST_DDE_CUH
#define GST_DDE_CUH
#include <device_launch_parameters.h>
#include <cuda_runtime.h>
#include <cuda.h>
#define HEIGHT 480
#define WIDTH 640
#define BLOCK_DIM 1024
#define GRID_DIM 300
#define BLOCK_DIM2 64
__global__
void BLUR(float* In, float* Out, int kDim, int inWidth, int outWidth, int outHeight);
void BLUR_wrapper(float* In, float* Out, int kDim, int inWidth, int outWidth, int outHeight);
#endif
gst_dde.cu looks like:
#include "gst_dde.cuh"
__global__
__global__
void BLUR(float* In, float* Out, int kDim, int inWidth, int outWidth, int outHeight) {
    extern __shared__ float loadIn[];
    int trueDimX = blockDim.x - (kDim - 1);
    int trueDimY = blockDim.y - (kDim - 1);
    int col = (blockIdx.x * trueDimX) + threadIdx.x;
    int row = (blockIdx.y * trueDimY) + threadIdx.y;
    if ((0 <= col)&& (col <= outWidth + 1) && (0 <= row) && (col <= outHeight + 1)) {
        if ((col == 0) || (row == 0)) {
            if ((row < outHeight) && (col < outWidth)) {
                loadIn[threadIdx.y * blockDim.x + threadIdx.x] = In[row * inWidth + col];
            if ((row == outHeight) || (row == outHeight + 1)) {
                loadIn[threadIdx.y * blockDim.x + threadIdx.x] = In[(outHeight - 1) * inWidth + col];
            if ((col == outWidth) || (col == outWidth + 1)) {
                loadIn[threadIdx.y * blockDim.x + threadIdx.x] = In[row * inWidth + outWidth - 1];
        else {
            if ((col < outWidth + 1) && (row < outHeight + 1)) {
                loadIn[threadIdx.y * blockDim.x + threadIdx.x] = In[(row - 1) * inWidth + col - 1];
            else {
                if (row == 1) {
                    loadIn[threadIdx.y * blockDim.x + threadIdx.x] = In[row * inWidth + col - 2];
                else {
                    if (col == 1) {
                        loadIn[threadIdx.y * blockDim.x + threadIdx.x] = In[(row - 2) * inWidth + col];
                    else {
                        loadIn[threadIdx.y * blockDim.x + threadIdx.x] = In[(row - 2) * inWidth + (col - 2)];
        __syncthreads();
        if (threadIdx.y < trueDimY && threadIdx.x < trueDimX) {
            float acc = 0;
            for (int i = 0; i < kDim; ++i) {
                for (int j = 0; j < kDim; ++j) {
                    acc = acc + loadIn[(threadIdx.y + i) * blockDim.x + (threadIdx.x + j)];
            Out[row * inWidth + col] = acc * (1.0 / kDim / kDim);
    else
        loadIn[threadIdx.y * blockDim.x + threadIdx.x] = 0.0;
    int bw = 16;
    int bwHalo = bw + (kDim - 1);
    dim3 dimBlock(bwHalo,bwHalo);
    dim3 dimGrid(ceil(WIDTH/float(bw)),ceil(HEIGHT/float(bw)));
    BLUR<<<dimGrid,dimBlock,bwHalo*bwHalo*sizeof(float)>>>(In,Out,kDim,inWidth,outWidth,outHeight);
And I also have some main.cpp file where I call BLUR_wrapper that shouldn’t be the problem.
I get this error when I build:
./gst_dde_cuda.o: Relocations in generic ELF (EM: 62)
error adding symbols: File in wrong format
collect2: error: ld returned 1 exit status
Can someone aid me with this? Is problem with location of saved .o file? should I be using NVCC from rootfs that I got from copying from Jetson that is my target or should I use NVCC that is installed on host? And is it a problem that I use CUDA 11 on host and have CUDA 8 on Jetson (that can be installed only on Ubuntu 14 and 16). Hope I am somewhat clear with my problem. Thank you.
