I’m fairly new to working with Jetsons and Jetson Orin NX in particular. I’m in the process of building a Linux kernel to accommodate for WireGuard VPN and some peripherals since the original setup does not support them. I tried to follow all the guides and procedures I found very strictly but unfortunately I did something I cannot reverse. Now it just turns on, shows Nvidia logo on the display briefly and then turns off (or at least I think it does - SSD diode blinks). I tried to flash it using NVidia SDK but it didn’t work (logs attached). In order to keep experimenting I desperately need a reliable method to restore my Orin to factory defaults and original OS.
For Orin NX, SDK Manager supports it only when it’s used with an Orin Nano DevKit, please use initrd flash manually if you want to use it with a Xavier NX DevKit.
For the backup/restore tool, you have to manually choose the storage device to be used; for example, -e nvme0n1, or it would use eMMC by default, which is not available on Orin NX/Nano.
For the error log:
09:45:45 INFO: Flash Jetson Linux - flash: [ 0.5380 ] Sending bct_br
09:45:50 ERROR: Flash Jetson Linux - flash: [ 0.5902 ] ERROR: might be timeout in USB write.
this issue has been around for while, and currently we would suggest trying for a different USB port/cable, or use Ubuntu 18.04 as the host PC in case it’s 20.04.
