Errors in File system andOS
Every time I swipe the jetson agx xavier , there are errors in the File System and OS. I don’t know how to solve them. I hope you can help me solve them.
Could you dump the full error log? I suspect the File exists is not the error that causes failure here…
What is under your Linux_for_Tegra/rootfs/dev/? Could you share us the result there?
SDKM_logs_JetPack_4.5.1_Linux_for_Jetson_AGX_Xavier_2021-03-17_16-43-46.zip (43.4 KB)
Did you already have Linux_for_Tegra on your host and you try to install with sdkmanager again?
From your log, the path is /home/cmz/sdk/JetPack_4.5.1_Linux_JETSON_AGX_XAVIER.
hi,I have it
by the way,my jetson can’t work
Please remove that folder and let sdkmanager re-download it again.
We should not deal with this boot problem at this moment since your driver package seems not completed. The log shows some basic components are gone. I guess that is due to the sdkmanager issue too.
I have tried many times, but the result is still like this
I am little bit confused here. What is your host environment to run sdkmanager?
Ubuntu 18.04
An x64 machine?
yes
Could you dump SDKM_logs_JetPack_4.5.1xxxx log again? Your error is different this time.
I think this is host side configuration problem. If you want to save time, try other host is also a method.
I think so
I appreciate your help very much.
If your host PC is an ordinary Ubuntu 18.04 desktop PC, then you should not see “exec format error”. Are you really sure that JetPack/SDKM is running on a host PC and not the Jetson?
I’m pretty sure.It’s just that the computer is a little old
