The Kaya build guide has some unfinished instructions, which need to be fixed. Here’s one example:
“Attach header cables to IMU leads (SPECIFY WHICH) - Make note of the colors you are using for each pin”.
[url]https://docs.nvidia.com/isaac/isaac/apps/tutorials/doc/assemble_kaya.html#[/url]
BTW, huge props to whoever did the 3D printable elements. They all work great! Very thoughtfully designed
Hi chris5pb1j,
Thanks for the feedback, and I’m glad that you’re having a positive experience with Kaya! An improved set of assembly instructions for Kaya is already in the works, with improved photos and instruction clarity. I believe that it will also address your specific feedback.
