Errors in the training model when batch_size_per_gpu is modified to be greater than 4
The GPU I use is v100. When I set the batch_size_per_gpu parameter to be greater than 4, the training model has the following error:
any idea?thanks.
I am afraid it is killed due to OOM(out of memory).
Can you attach your training spec?
This is my training spec
Copyright (c) 2017-2019, NVIDIA CORPORATION. All rights reserved.
random_seed: 42
enc_key: ‘’
verbose: True
network_config {
input_image_config {
image_type: RGB
image_channel_order: ‘bgr’
size_height_width {
height: 1080
width: 1920
image_channel_mean {
key: ‘b’
value: 103.939
key: ‘g’
value: 116.779
key: ‘r’
value: 123.68
image_scaling_factor: 1.0
max_objects_num_per_image: 100
feature_extractor: “resnet:50”
anchor_box_config {
scale: 64.0
scale: 128.0
scale: 256.0
ratio: 1.0
ratio: 0.5
ratio: 2.0
freeze_bn: True
freeze_blocks: 0
freeze_blocks: 1
roi_mini_batch: 256
rpn_stride: 16
conv_bn_share_bias: True
roi_pooling_config {
pool_size: 7
pool_size_2x: False
all_projections: True
use_pooling:False
training_config {
kitti_data_config {
data_sources: {
tfrecords_path: “/workspace/tlt-experiments/tfrecords/kitti_trainval/kitti_trainval*”
image_directory_path: “/workspace/tlt-experiments/data/training”
image_extension: ‘jpg’
target_class_mapping {
key: ‘box’
value: ‘box’
validation_fold: 0
data_augmentation {
preprocessing {
output_image_width: 1920
output_image_height: 1080
output_image_channel: 3
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 0
translate_max_y: 0
color_augmentation {
hue_rotation_max: 0.0
saturation_shift_max: 0.0
contrast_scale_max: 0.0
contrast_center: 0.5
enable_augmentation: True
batch_size_per_gpu: 4
num_epochs: 300
pretrained_weights: “/workspace/tlt-experiments/data/faster_rcnn/resnet50.hdf5”
output_model: “/workspace/tlt-experiments/data/faster_rcnn/frcnn_kitti_resnet50.tlt”
rpn_min_overlap: 0.3
rpn_max_overlap: 0.7
classifier_min_overlap: 0.0
classifier_max_overlap: 0.5
gt_as_roi: False
std_scaling: 1.0
classifier_regr_std {
key: ‘x’
value: 10.0
key: ‘y’
value: 10.0
key: ‘w’
value: 5.0
key: ‘h’
value: 5.0
rpn_mini_batch: 256
rpn_pre_nms_top_N: 12000
rpn_nms_max_boxes: 2000
rpn_nms_overlap_threshold: 0.7
reg_config {
reg_type: ‘L2’
weight_decay: 1e-4
optimizer {
adam {
lr: 0.00001
beta_1: 0.9
beta_2: 0.999
decay: 0.0
lr_scheduler {
step {
base_lr: 0.00001
gamma: 1.0
step_size: 30
lambda_rpn_regr: 1.0
lambda_rpn_class: 1.0
lambda_cls_regr: 1.0
lambda_cls_class: 1.0
inference_config {
images_dir: ‘/workspace/tlt-experiments/data/testing/image_2’
model: ‘/workspace/tlt-experiments/data/faster_rcnn/frcnn_kitti_resnet50.epoch300.tlt’
detection_image_output_dir: ‘/workspace/tlt-experiments/data/faster_rcnn/inference_results_imgs’
labels_dump_dir: ‘/workspace/tlt-experiments/data/faster_rcnn/inference_dump_labels’
rpn_pre_nms_top_N: 6000
rpn_nms_max_boxes: 300
bbox_visualize_threshold: 0.6
classifier_nms_max_boxes: 300
classifier_nms_overlap_threshold: 0.3
evaluation_config {
labels_dump_dir: ‘/workspace/tlt-experiments/data/faster_rcnn/test_dump_labels’
object_confidence_thres: 0.0001
use_voc07_11point_metric:False
Thanks for the info. For faster_rcnn, resnet50 or resnet101, see more info in Faster RCNN ResNet-101 Problems - #14 by zhimengf
and Low batch size during training
Thank you for your reply. I am using 4 v100, but bs can only be set to 4 at most, so I am very confused.
