After installing the SDK 2021.1 and following Getting Started documentation, got some errors. Need help/clarification.
---------------- package not found error
user@laptop:~/isaac-sdk/sdk$ bazel build -c dbg //apps/samples/pose_tensorrt_inference
ERROR: Skipping ‘//apps/samples/pose_tensorrt_inference’: no such package ‘apps/samples/pose_tensorrt_inference’: BUILD file not found in any of the following directories. Add a BUILD file to a directory to mark it as a package.
- /home/user/isaac-sdk/sdk/apps/samples/pose_tensorrt_inference
WARNING: Target pattern parsing failed.
INFO: Build options --action_env, --compilation_mode, --cpu, and 1 more have changed, discarding analysis cache.
INFO: Analyzed 0 targets (0 packages loaded, 0 targets configured).
INFO: Found 0 targets…
ERROR: command succeeded, but there were errors parsing the target pattern
INFO: Elapsed time: 0.169s, Critical Path: 0.00s
INFO: 1 process: 1 internal.
FAILED: Build did NOT complete successfully
