Errors messages due to the cuda rules ?
Hi every one,
I’m new by Cuda and I downloaded the CUDA Toolkit 3.2 RC2 on my Windows XP machine and I
tested successfully “the bandwidth Test” and other examples. I also added in Visual Studio 2008 the cuda rules
in the folder C:\Programs\Microsoft Visual Studio 9.0\VC\VCProjectDefaults. There are actually
4 rules data :NvCudaDriverApi.rules,NvCudaDriverApi.v3.2.rules,NvCudaRuntimeApi.rules and NvCudaRuntimeApi.v3.2.rules.
I selected the custom build rules in the project explorer and checked the NvCudaRuntimeApi.v3.2.rules.
I compiled the following files:
//test.cpp file
#include
#include “cuda.h”
#include “host_defines.h”
#include “cuda_runtime.h”
#include “device_launch_parameters.h”
#include “driver_types.h”
#include “common_functions.h”
#include “host_config.h”
#include “host_runtime.h”
#include “driver_functions.h”
#include “func_macro.h”
#pragma comment (lib, “cuda.lib”)
using namespace std
global void add(int a, int b, int *c){
*c=a+b;
int main(){
int c;
int *dev_c;
cudaMalloc((void**)&dev_c, sizeof(int));
add<<<1,1>>>(2,7,dev_c);
cudaMemcpy(&c,dev_c,sizeof(int),cudaMemcpyDeviceToHost);
printf(“2+7=%d\n”,c);
cudaFree(dev_c);
return 0;
//test.cu file
using namespace std
*c=a+b;
int main(){
int c;
int *dev_c;
cudaFree(dev_c);
return 0;
and I had the error message:
error PRJ0019: a tool returned an error code from the following source: “Compiling with CUDA Build Rule…”
does someone have an idea what I’m doing wrong???
Thank you
Hi every one,
//test.cpp file
#include
#include “cuda.h”
using namespace std
*c=a+b;
int main(){
int c;
int *dev_c;
cudaFree(dev_c);
return 0;
//test.cu file
using namespace std
*c=a+b;
int main(){
int c;
int *dev_c;
cudaFree(dev_c);
return 0;
Thank you
I fixed the error!! i saw what I was doing wrong!!!
