Hi,I had the following problem with remote compilation of Jetson TX2 using nsight。
Errors occurred during the build.
Errors running builder ‘CDT Builder’ on project ‘test’.
Internal error building project test configuration Debug
Merge conflict
Merge conflict
When setting up the project, I set the IP address of TX2 to 192.168.1.77, which can be compiled successfully. When I run on TX2 program modify IP address is 192.168.0.77. After I restored the IP to 192.168.1.77, the above problem occurred when compiling on the host.
My operating system is Ubuntu16.04, Nsight 9.0.Please reply to me as soon as possible. Thank you very much.
