Hey everyone!
I had a working machine in which Nvidia worked perfectly. Now, I issued the update & upgrade command to perform those action on the system wide installed packages. This introduced some unexpected issues, altough I’ve done the same many times before without any conflicts.
capracop@Legion-5:~$ sudo dpkg --configure -a
Setting up initramfs-tools (0.130ubuntu3.13) …
update-initramfs: deferring update (trigger activated)
Setting up linux-image-5.4.0-124-generic (5.4.0-124.140~18.04.1) …
I: /initrd.img is now a symlink to boot/initrd.img-5.4.0-124-generic
Setting up nvidia-kernel-common-510 (510.85.02-0ubuntu0.18.04.1) …
/usr/sbin/update-initramfs: 207: /usr/sbin/update-initramfs: awk: not found
dpkg: error processing package nvidia-kernel-common-510 (–configure):
installed nvidia-kernel-common-510 package post-installation script subprocess returned error exit status 127
dpkg: dependency problems prevent configuration of nvidia-driver-510:
nvidia-driver-510 depends on nvidia-kernel-common-510 (<= 510.85.02-1); however:
Package nvidia-kernel-common-510 is not configured yet.
nvidia-driver-510 depends on nvidia-kernel-common-510 (>= 510.85.02); however:
Package nvidia-kernel-common-510 is not configured yet.dpkg: error processing package nvidia-driver-510 (–configure):
dependency problems - leaving unconfigured
Setting up linux-image-5.19.0-1.1-liquorix-amd64 (5.19-1ubuntu1~bionic) …
I: /initrd.img.old is now a symlink to boot/initrd.img-5.19.0-1.1-liquorix-amd64
/etc/kernel/postinst.d/apt-auto-removal:
/etc/kernel/postinst.d/apt-auto-removal: 21: /etc/kernel/postinst.d/apt-auto-removal: awk: not found
/etc/kernel/postinst.d/apt-auto-removal: 26: /etc/kernel/postinst.d/apt-auto-removal: awk: not found
run-parts: /etc/kernel/postinst.d/apt-auto-removal exited with return code 127
dpkg: error processing package linux-image-5.19.0-1.1-liquorix-amd64 (–configure):
installed linux-image-5.19.0-1.1-liquorix-amd64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-dkms-510:
nvidia-dkms-510 depends on nvidia-kernel-common-510 (<= 510.85.02-1); however:
nvidia-dkms-510 depends on nvidia-kernel-common-510 (>= 510.85.02); however:
Package nvidia-kernel-common-510 is not configured yet.dpkg: error processing package nvidia-dkms-510 (–configure):
dpkg: dependency problems prevent configuration of linux-image-liquorix-amd64:
linux-image-liquorix-amd64 depends on linux-image-5.19.0-1.1-liquorix-amd64 (= 5.19-1ubuntu1~bionic); however:
Package linux-image-5.19.0-1.1-liquorix-amd64 is not configured yet.dpkg: error processing package linux-image-liquorix-amd64 (–configure):
Processing triggers for initramfs-tools (0.130ubuntu3.13) …
dpkg: error processing package initramfs-tools (–configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 127
Processing triggers for linux-image-5.4.0-124-generic (5.4.0-124.140~18.04.1) …
dpkg: error processing package linux-image-5.4.0-124-generic (–configure):
installed linux-image-5.4.0-124-generic package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
nvidia-driver-510
nvidia-dkms-510
initramfs-tools
I googled and tried the recommended suggestions to tackle those broken packages with the following commands. However, without any success.
1. sudo dpkg --configre -a
2. sudo apt -f install
Does anyone have any ideas what to do?
System: Ubuntu 18.04 LTS
Laptop: Lenovo Legion 5
GPU: Geforce RTX 3070
Processor: AMD Ryzen 5000
