Isaac sim version: 4.2
I try to use build in depth camera (RSD455) and stick it to my robot at specific location, but when I run the simulation, it keeps showing this error:
Here is how I set the RSD455:
I found one solution is that I should put the camera directly under the robot xfrom instead of head_frame xform , but the camera would fall to the ground if I did that. My request is just stick the depth camera to the robot head without this error, or should I just ignore them?
