Hi, i’m trying to read Jetson’s stream from another pc using opencv
So here is config file
config_main.txt (1.3 KB)
On another pc:
cv2.VideoCapture("rtsp://address", cv2.CAP_FFMPEG")
After getting first frame from Jetson i got this warning on Jetson:
(deepstream-app:22031): GLib-GObject-WARNING **: 17:52:10.502: g_object_get_is_valid_property: object class 'GstUDPSrc' has no property named 'pt'
Frame that I got on another pc is NoneType and after Jetson is lagging on 30-45 seconds and tries to stream one fore frame
If I reading stream with gstreamer on another pc it hasn’t got any problems
Is the PC in the same LAN as the jetson? And please help provide complete information as applicable to your setup.
• DeepStream Version
• TensorRT Version
• The pipeline being used
• Jetson AGX Xavier
• Deepstream 6.0
• JetPack 4.6
• TensorRT 8.0.1
• NVIDIA GPU Driver 32.6.1
On server(Jetson) I use yolov5 for detection people in masks and if people is not in mask I recognite them with facenet and make post request to client with id of people in database
On client(PC) I getting Id of people and if people doesn’t wear first time a day client trying to get rtsp, take one image and save it into database
deepstream_app_main.c (26.5 KB)
What is the problem?
Is this the source or the output of deepstream?
So there is nothing wrong with deepstream rtsp output.
Ok, I’ll trying to send this image with post request but I can’t get cv::Mat from NvBufSurface.
I getting Surface in analytics_done_buf_prob()
function. But after save it intu jpg file I get image like this:
I get it with this code:
GstMapInfo in_map_info;
GstMapInfo inmap = GST_MAP_INFO_INIT;
if (!gst_buffer_map (buf, &inmap, GST_MAP_READ)) {
GST_ERROR ("input buffer mapinfo failed");
gst_buffer_unmap (buf, &in_map_info);
NvBufSurface *surface = (NvBufSurface *) inmap.data;
for (NvDsMetaList *l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)l_frame->data;
if (surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0] == NULL){
if (NvBufSurfaceMap(surface, frame_meta->batch_id, 0, NVBUF_MAP_READ) != 0)
std::cout << "Faild to map the surface buffer\n";
NvBufSurfaceSyncForCpu (surface, 0, 0);
guint height = surface->surfaceList[frame_meta->batch_id].height;
guint width = surface->surfaceList[frame_meta->batch_id].width;
Mat nv12_mat = Mat(height, width, CV_8UC1, surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0],
surface->surfaceList[frame_meta->batch_id].pitch);
Mat rgba_mat;
cvtColor(nv12_mat, rgba_mat, CV_YUV2BGRA_NV12);
imwrite("Mat.jpg", rgba_mat);
NvBufSurfaceUnMap (surface, frame_meta->batch_id, 0);
guint i = 0;
for (NvDsMetaList *l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) {
NvDsObjectMeta *obj = (NvDsObjectMeta *) l_obj->data;
std::string str = appCtx->predNames[i];
std::cout<<obj->class_id<<std::endl;
/*Init curl for POST-request*/
CURL *curl;
CURLcode res;
std::string readBuffer;
curl = curl_easy_init();
std::cout<<curl<<std::endl;
if (obj->class_id == 2){
str = "Unmasked |" + str;
if(curl) {
curl_easy_setopt(curl, CURLOPT_URL, "http://192.168.253.62:8000/");
curl_easy_setopt(curl, CURLOPT_POST, 1);
curl_easy_setopt(curl, CURLOPT_POSTFIELDS, "Id=" + appCtx->predNames[i] + "&cam=1");
res = curl_easy_perform(curl);
curl_easy_cleanup(curl);
Can you create new topic for new issue?
