I think it hasn’t been answered in my follow-up reply but I have been facing issues with the dbscan section of the project, the code is unable to provide an output for more than 45min (I just left it to run). This is the code I ran:
infected_df[‘cluster’] = dbscan.fit_predict(infected_df[[‘northing’, ‘easting’]])
infected_df[‘cluster’].nunique()
I am also constantly getting this error even after restarting the whole task:
TypingError: Failed in nopython mode pipeline (step: nopython frontend)
Internal error at <numba.core.typeinfer.CallConstraint object at 0x7f9fa63de4d0>.
module, class, method, function, traceback, frame, or code object was expected, got CPUDispatcher
During: resolving callee type: Function(<numba.cuda.compiler.DeviceFunctionTemplate object at 0x7f9fa63de150>)
During: typing of call at /opt/conda/envs/rapids/lib/python3.7/site-packages/cudf/utils/cudautils.py (102)
Enable logging at debug level for details.
File “…/…/opt/conda/envs/rapids/lib/python3.7/site-packages/cudf/utils/cudautils.py”, line 102:
def gpu_mark_found_int(arr, val, out, not_found):
if i < arr.size:
if check_equals_int(arr[i], val):
My time for the course has also been used up during this troubleshooting, so I’ll like to request for more time as well, thanks so much in advance.
Claire
