SDK 35.4.1
ES8336 is connected to I2S1 and I2C2(based on a previous project using I2S0 and I2C2)
I used the following command to record cap.wav
arecord -D hw:1,0 -f S16_LE -c 2 -r 44100 -d 5 cap.wav
Recording WAVE 'cap.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
[ 1868.770122] ------------[ cut here ]------------
[ 1868.774955] WARNING: CPU: 3 PID: 3488 at drivers/gpio/gpiolib.c:122 gpio_to_desc+0xb4/0x100
[ 1868.783865] ---[ end trace 01cc401fd835306d ]---
Before that, I also executed the following script with reference to a previous project that used I2S0
amixer -c APE cset name="ADMAIF1 Mux" "I2S4"
amixer -c APE cset name="I2S4 Mux" "ADMAIF1"
amixer -c APE cset name="ES Left Hp mixer Left DAC Switch" 1
amixer -c APE cset name="ES Right Hp mixer Right DAC Switch" 1
I changed I2S0 to I2S1 and commented out the 40-headers pinmux
diff --git a/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/tegra234-p3767-common-audio.dtsi b/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/tegra234-p3767-common-audio.dtsi
index 4da1a227d..d47679d56 100644
--- a/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/tegra234-p3767-common-audio.dtsi
+++ b/hardware/nvidia/platform/t23x/p3768/kernel-dts/cvb/tegra234-p3767-common-audio.dtsi
@@ -10,7 +10,7 @@
#include <audio/tegra186-audio-dai-links.dtsi>
#include <audio/tegra186-audio-graph.dtsi>
-#define SPK_EN TEGRA234_AON_GPIO(EE, 2) //GPIO10 #341 speaker eanble
+//#define SPK_EN TEGRA234_AON_GPIO(EE, 2) //GPIO10 #341 speaker eanble
aconnect@2a41000 {
@@ -23,9 +23,10 @@
+ //i2s4
ahub {
status = "okay";
- i2s@2901100 {
+ i2s@2901300 {
status = "okay";
@@ -42,7 +43,7 @@
#sound-dai-cells = <0>;
compatible = "everest,es8336";
reg = <0x10>;
- spk-con-gpio = <&tegra_aon_gpio SPK_EN GPIO_ACTIVE_HIGH>;
+ //spk-con-gpio = <&tegra_aon_gpio SPK_EN GPIO_ACTIVE_HIGH>;
status = "okay";
@@ -229,7 +230,7 @@
// add by xiaoz
//Specific overrides for I2S2 DAI link */
-&i2s2_to_codec {
+&i2s4_to_codec {
link-name = "es8316-playback";
codec {
sound-dai = <&es8316_codec 0>;
diff --git a/hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-sv-p3767-0000-p3509-a02.dts b/hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-sv-p3767-0000-p3509-a02.dts
index 50a517ac4..0d95d0fa5 100644
--- a/hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-sv-p3767-0000-p3509-a02.dts
+++ b/hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-sv-p3767-0000-p3509-a02.dts
@@ -133,6 +133,7 @@
//es8316
pinmux@2430000 {
status = "okay";
pinctrl-0 = <&audio_pinmux>;
@@ -187,5 +188,5 @@
Is there anything wrong and how can I debug this problem.
