SDK version jetpack 6.2 jetson linux r36.4.4
The ES8336 can hear normal sound when playing music, but there is a very noticeable noise
I use i2s4 and i2c0
output.dts.txt (314.7 KB)
tegra234-p3768-0000.dtsi.txt (1.7 KB)
I use i2s4 and i2c0
Based on the provided context, I’ll try to address the issue you’re facing with the Jetson Orin NX SDK.
Problem Statement:
You’re experiencing a noticeable noise when playing music using the ES8336 codec on the Jetson Orin NX, despite being able to hear normal sound. You’re using I2S4 and I2C0 output.
Possible Causes:
tegra234-p3737-audio.dtsi) to ensure that the ES8336 codec is properly configured and connected to the I2S4 and I2C0 interfaces.Comparison with Other Jetson Modules:
The Jetson Orin NX is a different module compared to the Jetson AGX Orin, which has a different audio architecture. The Jetson AGX Orin has an RT5640 codec, whereas the Jetson Orin NX uses the ES8336 codec. This difference might require specific configuration and tuning for the ES8336 codec.
Recommendations:
By following these recommendations, you should be able to identify and resolve the issue causing the noise in the audio output.
Hi lzyu1110,
Are you using the devkit or custom board for Orin NX?
Please also share the full dmesg for further check.
Is there any error when you get “very noticeable noise”?
custom board
i didn’t find any errors in log file when playback
dmesg.txt (147.1 KB)
any suggestions?
Please check your HW design for any noise affecting I2S and Audio codec signals. Using oscilloscope to check I2S and audio codec signals might help you debug further to find source of noise coupling, if any.
[ 11.821589] xiaoz es8336_i2c_probe
[ 11.821724] es8336 0-0010: xiaoz Can not read property spk_ctl_gpio
[ 11.821730] es8336 0-0010: Can not read property hp_det_gpio
I found above 2 error reported in the dmesg you shared.
Please also check if you’ve ported them correctly and the current noise issue may be caused due to missing them.
