We’ve been using the ESS most on a Jetson Orin for robot navigation and it’s been great. We also have a usecase where we need to use this model without a GPU. Is it possible to run the model without TensorRT? I noticed it’s using 4 custom layers which are supplied in pre built binaries for TensorRT only as a plug-in. Is there a similar plug-in for onnxruntime?
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
- TensorFlow: Installing TensorFlow for Jetson Platform - NVIDIA Docs
- PyTorch: Installing PyTorch for Jetson Platform - NVIDIA Docs
We also have containers that have frameworks preinstalled:
Data Science, Machine Learning, AI, HPC Containers | NVIDIA NGC
3. Tutorial
Startup deep learning tutorial:
- Jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson
- TensorRT sample: Jetson/L4T/TRT Customized Example - eLinux.org
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
If your model can run with PyTorch or other frameworks with CPU mode, you can deploy it on Jetson without using GPU.
For the plugin problem, you can check if the layers are listed in the ONNXRuntime document below:
ESS is an Nvidia supplied model from the NGC ESS DNN Stereo Disparity | NVIDIA NGC
The older versions (pre 4.0) used to be convertable to ONNX easily and could be run anywhere. With 4.0 some fused operations were created and added which can only run on TensorRT. If code or ONNX plugins for those operations could be provided that would be very helpful.
TensorRT is supported on the Jetson Orin.
Based on the “Performance” section below, the model should be able to run on AGX Orin:
Does using TensorRT work for you?
