Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.5.1.7815
Host Machine Version
native Ubuntu 18.04
We are trying to use NvsciIPC for interprocess communication on Xavier A.
The inter-process communication is successful by establishing 1 channel between 2 endpoints.
The usecase that I am working on has a requirement to send the data from 1 endpoint to multiple endpoints and receive the data at 1 endpoint from multiple endpoints.
In order to achieve this we added the following to nvsciipc.cfg:
INTER_PROCESS ipc_endpt_0 ipc_endpt_1 16 2271552
INTER_PROCESS ipc_endpt_0 ipc_endpt_2 16 2271552
In the above case ipc_endpt_0 will have to handle 2 channels to send the data to ipc_endpt_1, ipc_endpt_2. On trying this we observe an endpoint creation failure to the receiver which is spawned second.
Please confirm, is it possible to have multiple channels attached to the same endpoint?
Note: Also when we tried to create 2 channels between separate endpoints they worked fine simultaneously.
