Establishing Real-Time Control of GR1_T2 Robot from Visual Studio Code
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA RTX 5000 Ada Generation GPU
  • Driver Version: 575.64.03
Topic Description
Detailed Description
Trying to control GR1_T2 robot from Ubuntu terminal as well as Python code in Visual Studio Code but sending joint commands via ROS2 results in no robot movement. Tried adjusting damping/stiffness values and joint command parameters, & verified Action Graph is set up correctly but robot does not move despite publishing joint commands. Verified that joint commands are correctly being published to ROS2 but they do not result in real-time robot movement. Instead, robot starts falling and its hands rotate 45 deg when the simulation is started. The robot should be immobile upon simulation start and should only move when issued joint commands.
Steps to Reproduce
  1. Load USD file (https://drive.google.com/file/d/1fjge3HssHbFEcYvZd65Y1hFLlJvGpaOX/view?usp=sharing)
  2. Start simulation in Isaac Sim.
  3. Send joint commands via ROS2 pub commands from either terminal or Visual Studio Code, e.g.:
    ros2 topic pub /joint_command sensor_msgs/msg/JointState “{header: {stamp: {sec: 0, nanosec: 0}, frame_id: ‘’}, name: [‘r_wrist_pitch’], position: [0.5], velocity: [0.0], effort: [0.0]}”
Error Messages
None
Screenshots or Videos
None
Additional Information
What I’ve Tried
Related Issues
Additional Context
Got robot to move but it eventually falls.
Hi @shamit.patel, thank you for your question. Are you fixing the robot in the air when trying to send commands? Fixing body frame in Isaac Sim. This seems like it would get you to your desired behavior.
Robot is standing on the ground when commands are sent.
Could you share a video of what you are observing on your end? I’d expect the robot to fall at the start of simulation unless the base is fixed or you are running a controller to balance the robot.
I got the robot to stand at beginning of simulation by increasing damping and stiffness values of load-bearing joints (see latest USD at https://drive.google.com/file/d/1fjge3HssHbFEcYvZd65Y1hFLlJvGpaOX/view?usp=sharing). If these are not reasonable please let me know. Thanks.
Attached video shows outcome of starting the simulation then running the following command from Ubuntu terminal:
ros2 topic pub /joint_command sensor_msgs/msg/JointState “{header: {stamp: {sec: 0, nanosec: 0}, frame_id: ‘’}, name: [‘l_hip_pitch’, ‘l_knee_pitch’, ‘l_ankle_pitch’, ‘r_hip_pitch’, ‘r_knee_pitch’, ‘r_ankle_pitch’], position: [0.0, -0.2, 0.0, 0.3, -0.4, -0.1], velocity: , effort: }” --rate 1
Hi @shamit.patel, for the robot to stand reliably, I believe there needs to be a balance controller sending joint commands to the entire lower body.
To just verify that the correct joints are being actuated, fixing the robot base would allow you to send these commands without the robot falling. Could you try running this with the robot base fixed to verify actuation?
@shalinj The robot needs to be controlled via Xbox Series X controller without falling. However when running the Xbox teleoperation script (see below) then starting the simulation, the robot tilts forward and falls despite presence of self-balancing controller. Also Xbox controller input fails to articulate some joints.
P.S. The robot cannot be fixed to the ground as it needs to be able to navigate the environment.
xbox_teleop.py:
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import JointState
import pygame
import time
JOINT_MODES = {
    'legs': [
        "l_hip_yaw", "l_hip_pitch", "l_knee_pitch", "l_ankle_pitch", "l_ankle_roll",
        "r_hip_yaw", "r_hip_pitch", "r_knee_pitch", "r_ankle_pitch", "r_ankle_roll"
    'arms': [
        "l_shoulder_pitch", "l_elbow_pitch", "l_wrist_pitch",
        "r_shoulder_pitch", "r_elbow_pitch", "r_wrist_pitch"
    'hands': [
        "L_index_proximal_joint", "L_thumb_proximal_yaw_joint", "L_thumb_proximal_pitch_joint",
        "R_index_proximal_joint", "R_thumb_proximal_yaw_joint", "R_thumb_proximal_pitch_joint"
# Adjusted INITIAL_POSE for a more neutral stable stance
INITIAL_POSE = {
    "l_hip_pitch": 0.05,  # Reduced backward tilt
    "r_hip_pitch": 0.05,
    "l_knee_pitch": 0.4,  # Moderate knee bend
    "r_knee_pitch": 0.4,
    "l_ankle_pitch": -0.05,  # Reduced forward ankle tilt
    "r_ankle_pitch": -0.05,
    "l_ankle_roll": 0.0,
    "r_ankle_roll": 0.0,
    "l_hip_yaw": 0.0,
    "r_hip_yaw": 0.0,
    "joint_waist_pitch": 0.0,
    "joint_waist_yaw": 0.0,
    "joint_waist_roll": 0.0,
    "joint_head_pitch": 0.0,
    "joint_head_yaw": 0.0,
    "joint_head_roll": 0.0,
    "l_shoulder_pitch": 0.2,
    "r_shoulder_pitch": 0.2,
    "l_elbow_pitch": 0.3,
    "r_elbow_pitch": 0.3,
    "l_wrist_pitch": 0.0,
    "r_wrist_pitch": 0.0,
    "l_wrist_roll": 0.0,
    "r_wrist_roll": 0.0,
    "l_wrist_yaw": 0.0,
    "r_wrist_yaw": 0.0
class XboxTeleopInitPose(Node):
    def __init__(self):
        super().__init__('xbox_teleop_with_pose')
        self.publisher = self.create_publisher(JointState, '/joint_command', 10)
        try:
            self.get_logger().set_level(10)
            self.get_logger().info("Debug logging enabled.")
        except AttributeError:
            self.get_logger().info("Debug logging not supported; using default level.")
        pygame.init()
        pygame.joystick.init()
        if pygame.joystick.get_count() > 0:
            self.joystick = pygame.joystick.Joystick(0)
            self.joystick.init()
            self.get_logger().info(f"Controller detected: {self.joystick.get_name()}, Axes: {self.joystick.get_numaxes()}, Buttons: {self.joystick.get_numbuttons()}")
        else:
            self.get_logger().error("No controller detected.")
            return
        self.joint_positions = INITIAL_POSE.copy()
        for mode_joints in JOINT_MODES.values():
            for joint in mode_joints:
                if joint not in self.joint_positions:
                    self.joint_positions[joint] = 0.0
        self.mode = 'legs'
        self.limb = 'left'
        self.current_joint_index = 0
        # Adjusted self-balancing controller parameters
        self.target_pitch = 0.0
        self.kp = 15.0  # Reduced proportional gain
        self.kd = 2.0   # Reduced derivative gain
        self.prev_error = 0.0
        self.last_time = time.time()
        time.sleep(2.0)
        self.send_initial_pose()
        self.timer = self.create_timer(0.01, self.update)  # Increased to 100 Hz
    def send_initial_pose(self):
        joint_msg = JointState()
        joint_msg.name = list(self.joint_positions.keys())
        joint_msg.position = list(self.joint_positions.values())
        for i in range(200):  # Increased to 200 iterations (20 seconds)
            self.publisher.publish(joint_msg)
            time.sleep(0.1)
            self.get_logger().info(f"Initial pose published, iteration {i+1}/200")
        self.get_logger().info("Initial stable pose published and settled.")
    def get_active_joints(self):
        prefix = self.limb[0]
        return [j for j in JOINT_MODES.get(self.mode, []) if j.startswith(prefix)]
    def update(self):
        if not hasattr(self, 'joystick') or not self.joystick:
            return
        pygame.event.pump()
        axes = [self.joystick.get_axis(i) for i in range(self.joystick.get_numaxes())]
        buttons = [self.joystick.get_button(i) for i in range(self.joystick.get_numbuttons())]
        hats = self.joystick.get_hat(0)
        self.get_logger().info(f"Axes: {axes}, Buttons: {buttons}, Hats: {hats}")
        # Mode and limb switching
        if hats[1] == 1: self.mode = 'arms'
        elif hats[1] == -1: self.mode = 'legs'
        elif hats[1] == 0 and hats[0] == 0: self.mode = 'hands'
        if hats[0] == 1: self.limb = 'right'
        elif hats[0] == -1: self.limb = 'left'
        active_joints = self.get_active_joints()
        if not active_joints:
            self.get_logger().warning("No active joints for current mode/limb.")
            return
        if buttons[4]: self.current_joint_index = (self.current_joint_index - 1) % len(active_joints)  # L1
        if buttons[5]: self.current_joint_index = (self.current_joint_index + 1) % len(active_joints)  # R1
        selected_joint = active_joints[self.current_joint_index]
        # Xbox control
        delta_scale = 0.1
        left_y = axes[1] if abs(axes[1]) > 0.1 else 0.0
        right_x = axes[3] if abs(axes[3]) > 0.1 else 0.0
        if left_y != 0.0 or right_x != 0.0:
            self.joint_positions[selected_joint] += delta_scale * -left_y
            if self.mode == 'legs' and 'yaw' in selected_joint:
                self.joint_positions[selected_joint] += delta_scale * right_x
        delta_fine = 0.02
        l2 = axes[4] if abs(axes[4]) > 0.5 else 0.0
        r2 = axes[5] if abs(axes[5]) > 0.5 else 0.0
        if l2 < 0.0:
            self.joint_positions[selected_joint] -= delta_fine
        if r2 > 0.0:
            self.joint_positions[selected_joint] += delta_fine
        if self.mode == 'hands':
            if buttons[0]:  # A
                for j in active_joints:
                    self.joint_positions[j] = min(self.joint_positions[j] + 0.1, 0.5)
            if buttons[1]:  # B
                    self.joint_positions[j] = max(self.joint_positions[j] - 0.1, -0.5)
            if buttons[2]:  # X
                    self.joint_positions[j] = 0.0
            if buttons[3]:  # Y
                    self.joint_positions[j] = 0.3
        # Enhanced self-balancing controller with debug logging
        current_time = time.time()
        dt = current_time - self.last_time
        if dt > 0.0:
            # Estimate tilt from average hip pitch
            hip_pitch = (self.joint_positions["l_hip_pitch"] + self.joint_positions["r_hip_pitch"]) / 2.0
            tilt_error = self.target_pitch - hip_pitch  # Positive = tilting backward
            d_error = (tilt_error - self.prev_error) / dt
            # PD controller
            correction = self.kp * tilt_error + self.kd * d_error
            # Apply symmetric correction
            for joint in ["l_ankle_pitch", "r_ankle_pitch", "l_hip_pitch", "r_hip_pitch"]:
                if joint in self.joint_positions:
                    self.joint_positions[joint] += correction * 0.015  # Reduced scale
                    self.joint_positions[joint] = max(min(self.joint_positions[joint], 0.5), -0.5)
            self.prev_error = tilt_error
            self.last_time = current_time
            self.get_logger().info(f"Balancing: Tilt Error={tilt_error:.3f}, Correction={correction:.3f}, KP={self.kp:.1f}, KD={self.kd:.1f}")
        # Clamp joint positions
        for joint in self.joint_positions:
        # Publish joint commands
        self.get_logger().info(f"Published {selected_joint}: {self.joint_positions[selected_joint]:.2f}")
        self.get_logger().info(f"[{self.mode.upper()} - {self.limb.upper()}] Joint: {selected_joint}, Pos: {self.joint_positions[selected_joint]:.2f}")
def main(args=None):
    rclpy.init(args=args)
    node = XboxTeleopInitPose()
    try:
        rclpy.spin(node)
    except KeyboardInterrupt:
        node.get_logger().info("Shutting down")
        pygame.quit()
    finally:
        node.destroy_node()
        rclpy.shutdown()
if __name__ == '__main__':
    main()
