Hi everyone, today I lost Ethernet access, using ifconfig -a gives on eth0 interface a device interrup 41 message, AGX doesn’t have anything on GPIOS.
Trying cat /proc/interrupts gives:
41: 2 0 0 0 0 0 0 0 GICv2 226 Level ether_qos.common_irq
It’s a Xavier AGX 16GB, module P2888-0001, board P2822-0000 with Jetpack 4.5.1.
Thank you
Please share the dmesg with ethernet connected.
Again, could you remove any peripheral out from the jetson and only leave the ethernet cable and necessary things to dump log?
This feels like hardware detection problem. Would you mind flashing your board to latest release and see if the issue would be gone?
