Hi Nvidia,
We are trying to update Jetson AGX Orin devkit from R35.1 to R35.3.1.
Because we plugged Orin devkit on our own motherboard instead of the original one, we removed the eeprom reading since we don’t have eeprom in our hardware design. In R35.1, we have already used it for a period of time and it works fine.
The 10G-XFI eth driver looks normal:
d@d-desktop:~$ sudo dmesg | grep ether
[ 4.389505] usbcore: registered new interface driver cdc_ether
[ 13.099387] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 13.106026] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 13.114180] nvethernet 6810000.ethernet: failed to read MDIO address
[ 13.120720] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 13.127625] nvethernet 6810000.ethernet: Failed to read DMA Tx ring size, using default [4096]
[ 13.136477] nvethernet 6810000.ethernet: Failed to read DMA Tx ring size, using default [4096]
[ 13.145329] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 13.536366] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:7f:53:88
[ 13.544302] nvethernet 6810000.ethernet: Macsec not enabled
[ 13.550033] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 13.559288] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 15.123619] using random self ethernet address
[ 15.135002] using random host ethernet address
[ 15.984788] using random self ethernet address
[ 15.989391] using random host ethernet address
[ 18.037397] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
And there is eth0 in ifconfig:
d@d-desktop:~$ ifconfig -a
dummy0: flags=130<BROADCAST,NOARP> mtu 1500
ether a6:5a:a6:3d:9f:dc txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1466
ether 48:b0:2d:7f:53:88 txqueuelen 1000 (Ethernet)
l4tbr0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.55.1 netmask 255.255.255.0 broadcast 192.168.55.255
inet6 fe80::f43a:9aff:fe79:26b5 prefixlen 64 scopeid 0x20<link>
inet6 fe80::1 prefixlen 128 scopeid 0x20<link>
ether f6:3a:9a:79:26:b5 txqueuelen 1000 (Ethernet)
RX packets 243 bytes 37466 (37.4 KB)
TX packets 277 bytes 32277 (32.2 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 541 bytes 38955 (38.9 KB)
TX packets 541 bytes 38955 (38.9 KB)
rndis0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 150 bytes 22802 (22.8 KB)
TX packets 413 bytes 71391 (71.3 KB)
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::f43a:9aff:fe79:26b7 prefixlen 64 scopeid 0x20<link>
ether f6:3a:9a:79:26:b7 txqueuelen 1000 (Ethernet)
RX packets 98 bytes 15584 (15.5 KB)
TX packets 179 bytes 37592 (37.5 KB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 90:e8:68:83:e5:91 txqueuelen 1000 (Ethernet)
So when we update it to R35.3.1, we supposed to make the same change as we did in R35.1 as below: (This is the only change we made after downloaded the package from Nvidia!)
In Linux/bootloader/tegra234-mb2-bct-common.dtsi
eeprom {
cvm_eeprom_i2c_instance = <0>;
cvm_eeprom_i2c_slave_address = <0xa0>;
cvm_eeprom_read_size = <0x100>;
cvb_eeprom_i2c_instance = <0x0>;
cvb_eeprom_i2c_slave_address = <0xac>;
cvb_eeprom_read_size = <0x100>;
Change to:
eeprom {
cvm_eeprom_read_size = <0x000>;
cvb_eeprom_read_size = <0x000>;
Then run the flashing command:
$ sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
However, after flashing progress done and the device reboot, eth0 missing and the 10g-XFI driver seems failed to install:
[ 4.349183] usbcore: registered new interface driver cdc_ether
[ 11.972507] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 11.979137] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 11.987300] nvethernet 6810000.ethernet: failed to read MDIO address
[ 11.993849] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 12.000769] nvethernet 6810000.ethernet: Failed to read DMA Tx ring size, using default [4096]
[ 12.009634] nvethernet 6810000.ethernet: Failed to read DMA Tx ring size, using default [4096]
[ 12.018496] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 12.418343] ether_get_mac_address_dtb: bad mac address at /chosen/nvidia,ether-mac0: NULL.
[ 12.426860] nvethernet 6810000.ethernet: No MAC address in local DT!
[ 12.433407] nvethernet 6810000.ethernet: failed to get MAC address
[ 12.443937] nvethernet: probe of 6810000.ethernet failed with error -22
[ 15.177664] using random self ethernet address
[ 15.184475] using random host ethernet address
[ 17.253153] using random self ethernet address
[ 17.257811] using random host ethernet address
And there is no eth0 in ifconfig:
ether fe:90:ce:5f:3c:1d txqueuelen 1000 (Ethernet)
inet6 fe80::18da:5ff:fea7:b3ed prefixlen 64 scopeid 0x20<link>
ether 1a:da:05:a7:b3:ed txqueuelen 1000 (Ethernet)
RX packets 171 bytes 28998 (28.9 KB)
TX packets 188 bytes 22348 (22.3 KB)
RX packets 1461 bytes 107416 (107.4 KB)
TX packets 1461 bytes 107416 (107.4 KB)
RX packets 97 bytes 15789 (15.7 KB)
TX packets 298 bytes 53476 (53.4 KB)
inet6 fe80::18da:5ff:fea7:b3ef prefixlen 64 scopeid 0x20<link>
ether 1a:da:05:a7:b3:ef txqueuelen 1000 (Ethernet)
RX packets 82 bytes 14393 (14.3 KB)
TX packets 129 bytes 27272 (27.2 KB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.25.32.124 netmask 255.255.252.0 broadcast 172.25.35.255
inet6 fe80::a77c:65dd:90f2:f48d prefixlen 64 scopeid 0x20<link>
RX packets 14582 bytes 21368053 (21.3 MB)
TX packets 6272 bytes 636913 (636.9 KB)
How to fix this problem without enable eeprom reading?
Thanks and looking forward to quick reply.
BR
Ezra Zhang
