Hello, alanz.
I attatched “ifconfig” and"dmesg.log".
Please, refer as belows :
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3357) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 25 21:22:12 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2032640
[ 0.000000] DMA zone: 7184 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 459776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffd06000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2000880
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29080(88%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7190396K/8130560K available (15294K kernel code, 2934K rwdata, 6640K rodata, 8576K init, 609K bss, 186500K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a13d808 - 0xffffff800a1d5f7c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000766] Console: colour dummy device 80x25
[ 0.000778] console [tty0] enabled
[ 0.000787] bootconsole [tegra_comb_uart0] disabled
[ 0.000806] kmemleak: Kernel memory leak detector disabled
[ 0.000825] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000840] pid_max: default: 32768 minimum: 301
[ 0.001996] Security Framework initialized
[ 0.002598] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002608] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004305] ftrace: allocating 47104 entries in 185 pages
[ 0.393728] sched-energy: Sched-energy-costs installed from DT
[ 0.393753] ASID allocator initialised with 65536 entries
[ 0.428671] tegra-id: chipid=21917.
[ 0.428683] tegra-id: opt_subrevision=1.
[ 0.428710] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.428723] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.428732] DTB Build time: Jun 25 2020 21:27:47
[ 0.477013] CPU1: Booted secondary processor [4e0f0040]
[ 0.509116] CPU2: Booted secondary processor [4e0f0040]
[ 0.541190] CPU3: Booted secondary processor [4e0f0040]
[ 0.573392] CPU4: Booted secondary processor [4e0f0040]
[ 0.605334] CPU5: Booted secondary processor [4e0f0040]
[ 0.605535] Brought up 6 CPUs
[ 0.605584] SMP: Total of 6 processors activated.
[ 0.605604] CPU features: detected feature: Privileged Access Never
[ 0.605613] CPU features: detected feature: LSE atomic instructions
[ 0.605622] CPU features: detected feature: User Access Override
[ 0.605630] CPU features: detected feature: 32-bit EL0 Support
[ 0.607113] CPU: All CPU(s) started at EL2
[ 0.607171] alternatives: patching kernel code
[ 0.613652] devtmpfs: initialized
[ 0.649156] Initilizing CustomIPI irq domain
[ 0.649397] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.649411] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.660963] pinctrl core: initialized pinctrl subsystem
[ 0.661185] OS set in device tree is not L4T.
[ 0.661460] regulator-dummy: no parameters
[ 0.661751] Initializing plugin-manager
[ 0.661798] Plugin module not found
[ 0.661829] Plugin-manager status disabled
[ 0.662888] NET: Registered protocol family 16
[ 0.664017] pstore: using zlib compression
[ 0.664038] console [pstore-1] enabled
[ 0.664043] pstore: Registered ramoops as persistent store backend
[ 0.664049] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[ 0.684096] cpuidle: using governor menu
[ 0.685181] bpmp: waiting for handshake
[ 0.685188] bpmp: handshake completed
[ 0.685202] bpmp: synchronizing channels
[ 0.685211] bpmp: channels synchronized
[ 0.685217] bpmp: mail init ok
[ 0.687774] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.687965] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.687972] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.687979] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.687984] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.688014] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.688027] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.688073] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.688080] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.688088] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.688114] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.691013] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.691038] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.693691] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.694695] tegra_aon_clk_init: ok
[ 0.694703] Registering BPMP clocks...
[ 0.694796] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.695336] Serial: AMBA PL011 UART driver
[ 0.695466] tegra_powergate_init: DONE
[ 0.695545] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.695556] DTB Build time: Jun 25 2020 21:27:47
[ 0.698246] Tegra reboot handler registered.
[ 0.705470] iommu: Adding device 14160000.pcie to group 0
[ 0.706080] iommu: Adding device 141a0000.pcie to group 1
[ 0.707313] iommu: Adding device 2490000.ether_qos to group 2
[ 0.707784] iommu: Adding device 3100000.serial to group 3
[ 0.708229] iommu: Adding device 3110000.serial to group 4
[ 0.708616] iommu: Adding device 3140000.serial to group 5
[ 0.709177] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.709391] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.709409] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.709414] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.709419] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.709462] tegra-pmc: PMC Prod config success
[ 0.709668] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.709681] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.709966] iommu: Adding device 3460000.sdhci to group 6
[ 0.710453] iommu: Adding device 3210000.spi to group 7
[ 0.710809] iommu: Adding device 3230000.spi to group 8
[ 0.711152] iommu: Adding device 3270000.spi to group 9
[ 0.712329] iommu: Adding device 3160000.i2c to group 10
[ 0.712728] iommu: Adding device c240000.i2c to group 11
[ 0.713074] iommu: Adding device 3180000.i2c to group 12
[ 0.713419] iommu: Adding device 3190000.i2c to group 13
[ 0.713898] iommu: Adding device 31b0000.i2c to group 14
[ 0.714255] iommu: Adding device 31c0000.i2c to group 15
[ 0.714681] iommu: Adding device c250000.i2c to group 16
[ 0.715027] iommu: Adding device 31e0000.i2c to group 17
[ 0.715624] iommu: Adding device sound to group 18
[ 0.716094] iommu: Adding device 3510000.hda to group 19
[ 0.716633] iommu: Adding device bc00000.rtcpu to group 20
[ 0.718359] iommu: Adding device 13e10000.host1x to group 21
[ 0.718804] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.719234] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.719582] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.719945] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.720299] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.720691] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.721038] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.721411] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.721918] iommu: Adding device 15340000.vic to group 30
[ 0.722512] iommu: Adding device 15380000.nvjpg to group 31
[ 0.722870] iommu: Adding device 15500000.tsec to group 32
[ 0.723172] iommu: Adding device 15100000.tsecb to group 33
[ 0.723444] iommu: Adding device 15480000.nvdec to group 34
[ 0.723700] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.723978] iommu: Adding device 154c0000.nvenc to group 36
[ 0.724234] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.724684] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.725061] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.725578] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.729688] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.729771] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.730355] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.730407] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.732296] iommu: Adding device 15c10000.vi to group 42
[ 0.732460] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.732875] iommu: Adding device 14800000.isp to group 43
[ 0.733761] iommu: Adding device 16000000.pva0 to group 44
[ 0.734238] iommu: Adding device 16800000.pva1 to group 45
[ 0.734664] iommu: Adding device 15810000.se to group 46
[ 0.735015] iommu: Adding device 15820000.se to group 47
[ 0.735263] iommu: Adding device 15830000.se to group 48
[ 0.735524] iommu: Adding device 15840000.se to group 49
[ 0.735801] iommu: Adding device c1a0000.aon to group 50
[ 0.737259] iommu: Adding device d000000.bpmp to group 51
[ 0.737611] bpmp: ping status is 0
[ 0.737744] bpmp d000000.bpmp: firmware tag is 57f8a77779f848bf2ecf21dabee5645f
[ 0.740762] bpmp d000000.bpmp: probe ok
[ 0.742372] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.742813] iommu: Adding device smmu_test to group 52
[ 0.743829] mc: mapped MMIO address: 0xffffff800a590000 -> 0x2c10000
[ 0.743847] mc: mapped MMIO address: 0xffffff800a5b0000 -> 0x2c20000
[ 0.743865] mc: mapped MMIO address: 0xffffff800a5d0000 -> 0x2c30000
[ 0.743883] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 0.743897] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 0.743914] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2b80000
[ 0.743929] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b90000
[ 0.743943] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2ba0000
[ 0.743957] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2bb0000
[ 0.743971] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1700000
[ 0.743985] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1710000
[ 0.744000] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1720000
[ 0.744014] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1730000
[ 0.744029] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1740000
[ 0.744043] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1750000
[ 0.744057] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1760000
[ 0.744072] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1770000
[ 0.744142] mc-err: mcerr ops are set to t19x
[ 0.749737] iommu: Adding device 2600000.dma to group 53
[ 0.755518] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.756682] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.756721] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.756753] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.757059] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.764982] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.765044] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.765075] GPIO line 266 (w-disable1) hogged as output/high
[ 0.765106] GPIO line 264 (w-disable2) hogged as output/high
[ 0.765381] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.767796] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.767807] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.768538] iommu: Adding device 3550000.xudc to group 54
[ 0.769296] iommu: Adding device 3610000.xhci to group 55
[ 0.771437] arm64_ras arm64_ras: probed
[ 0.771820] ras_fhi_enable: FHI 468 enabled on CPU0
[ 0.771860] ras_fhi_enable: FHI 469 enabled on CPU1
[ 0.771960] ras_fhi_enable: FHI 470 enabled on CPU2
[ 0.772040] ras_fhi_enable: FHI 471 enabled on CPU3
[ 0.772109] ras_fhi_enable: FHI 472 enabled on CPU4
[ 0.772173] ras_fhi_enable: FHI 473 enabled on CPU5
[ 0.772370] carmel_ras_enable: RAS enabled on cpu0
[ 0.772555] carmel_ras_enable: RAS enabled on cpu1
[ 0.772815] carmel_ras_enable: RAS enabled on cpu2
[ 0.773004] carmel_ras_enable: RAS enabled on cpu3
[ 0.773210] carmel_ras_enable: RAS enabled on cpu4
[ 0.773434] carmel_ras_enable: RAS enabled on cpu5
[ 0.773500] carmel_ras carmel_ras: probed
[ 0.774539] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 477, noc_nonsecure_irq = 476>
[ 0.775023] tegra-cbb c600000.aon-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.775941] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.776918] tegra-cbb be00000.rce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.777777] tegra-cbb b600000.sce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.778120] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.779296] vdd-ac-bat: 5000 mV
[ 0.779740] vdd-sdmmc1-sw: 3300 mV
[ 0.780058] vdd-1v8-sd: 1800 mV
[ 0.780346] vdd-3v3-cvb: 3300 mV
[ 0.780647] vdd-1v8-cvb: 1800 mV
[ 0.780982] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.781058] vdd-epb-1v0: 1000 mV
[ 0.781418] avdd-cam-2v8: 2800 mV
[ 0.781784] vdd-fan: 5000 mV
[ 0.782086] vdd-hdmi-5v0: 5000 mV
[ 0.782392] vdd_sys_en: 1200 mV
[ 0.822206] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.827353] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.827706] SCSI subsystem initialized
[ 0.828008] libata version 3.00 loaded.
[ 0.828226] usbcore: registered new interface driver usbfs
[ 0.828302] usbcore: registered new interface driver hub
[ 0.828401] usbcore: registered new device driver usb
[ 0.839691] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.842756] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.853317] vdd-1v0: at 1000 mV
[ 0.861413] vdd-1v8-hs: at 1800 mV
[ 0.869389] vdd-1v8-ls: at 1800 mV
[ 0.877425] vdd-1v8-ao: at 1800 mV
[ 0.885435] vddio-ddr-1v1: at 1100 mV
[ 0.893231] vdd-rtc: at 800 mV
[ 0.894557] spmic-ldo1: at 2375 mV
[ 0.905279] vdd-ao-3v3: at 3300 mV
[ 0.917363] vddio-emmc-3v3: at 3300 mV
[ 0.918762] spmic-ldo4: at 1587 mV
[ 0.929378] vdd-usb-3v3: at 3300 mV
[ 0.941432] vddio-sdmmc1-3v3: at 3300 mV
[ 0.949474] vdd-csi-1v2: at 1200 mV
[ 0.951080] spmic-ldo8: at 1800 mV
[ 0.956061] GPIO line 246 (gpio_default) hogged as output/high
[ 0.957503] GPIO line 247 (gpio_default) hogged as output/high
[ 0.957885] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.958202] max77620 4-003c: max77620 probe successful
[ 0.958904] media: Linux media interface: v0.10
[ 0.958948] Linux video capture interface: v2.00
[ 0.960635] pps_core: LinuxPPS API ver. 1 registered
[ 0.960644] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.960682] PTP clock support registered
[ 0.961076] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.961396] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.961460] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.964521] trusty trusty: trusty version: Built: 21:16:17 Jun 25 2020
[ 0.964587] trusty trusty: selected api version: 3 (requested 3)
[ 0.966144] Advanced Linux Sound Architecture Driver Initialized.
[ 0.966791] Bluetooth: Core ver 2.22
[ 0.966874] NET: Registered protocol family 31
[ 0.966880] Bluetooth: HCI device and connection manager initialized
[ 0.966891] Bluetooth: HCI socket layer initialized
[ 0.966900] Bluetooth: L2CAP socket layer initialized
[ 0.966953] Bluetooth: SCO socket layer initialized
[ 0.975544] camchar: rtcpu character device driver loaded
[ 0.976181] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.976272] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 0.977670] clocksource: Switched to clocksource arch_sys_counter
[ 1.024898] VFS: Disk quotas dquot_6.6.0
[ 1.024996] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.025367] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.026810] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.026866] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.027055] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.027065] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.027097] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.027109] nvmap_page_pool_init: Total RAM pages: 1986015
[ 1.027120] nvmap_page_pool_init: nvmap page pool size: 248251 pages (969 MB)
[ 1.027278] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.027673] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.029931] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.043275] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.043498] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.043707] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.043923] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.044135] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.045274] la/ptsa driver initialized.
[ 1.045697] NET: Registered protocol family 2
[ 1.046469] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.046765] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.047350] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.047413] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.047534] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.048013] NET: Registered protocol family 1
[ 1.048653] RPC: Registered named UNIX socket transport module.
[ 1.048664] RPC: Registered udp transport module.
[ 1.048688] RPC: Registered tcp transport module.
[ 1.048698] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.048710] PCI: CLS 0 bytes, default 64
[ 1.048933] Trying to unpack rootfs image as initramfs...
[ 1.224254] Freeing initrd memory: 5432K
[ 1.244541] random: fast init done
[ 1.249721] host1x 13e10000.host1x: initialized
[ 1.251884] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.257385] audit: initializing netlink subsys (disabled)
[ 1.257431] audit: type=2000 audit(0.880:1): initialized
[ 1.258379] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.268295] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.269666] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.270366] 9p: Installing v9fs 9p2000 file system support
[ 1.275295] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.275505] io scheduler noop registered
[ 1.275782] io scheduler cfq registered (default)
[ 1.279803] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.313793] iommu: Adding device 2993000.adsp to group 56
[ 1.423736] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.424793] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.438265] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.438687] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.439256] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.439662] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.440101] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.443796] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.443985] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.446844] tsec 15500000.tsec: initialized
[ 1.448722] tsec 15100000.tsecb: initialized
[ 1.452813] nvdec 15480000.nvdec: initialized
[ 1.455514] nvdec 15140000.nvdec1: initialized
[ 1.461440] falcon 15340000.vic: initialized
[ 1.463611] falcon 15380000.nvjpg: initialized
[ 1.465507] falcon 154c0000.nvenc: initialized
[ 1.467604] falcon 15a80000.nvenc1: initialized
[ 1.471308] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.472736] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.474188] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.475606] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.476935] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.478234] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.479646] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.481043] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.484644] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.490338] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.490684] scare-pigeon 14b00000.isp-thi: initialized
[ 1.495914] pva 16000000.pva0: initialized
[ 1.501378] pva 16800000.pva1: initialized
[ 1.506205] nvdla 15880000.nvdla0: initialized
[ 1.511061] nvdla 158c0000.nvdla1: initialized
[ 1.512567] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.512581] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.512624] tegradccommon 15200000.dc_common: dma mapping done
[ 1.512746] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.512757] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.513159] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.513190] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.513456] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.513465] tegra_cec 3960000.tegra_cec: probed
[ 1.514219] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.514295] generic_infoframe_type: 0x87
[ 1.514401] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.514444] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 1.519312] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 1.519328] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 1.519340] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.519575] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.519586] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.522822] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.522830] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.525527] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.526796] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.526806] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.527144] kfuse 3830000.kfuse: initialized
[ 1.528499] tegradc 15200000.nvdisplay: probed
[ 1.529215] Console: switching to colour frame buffer device 80x30
[ 1.529250] tegradc 15200000.nvdisplay: fb registered
[ 1.529686] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.530084] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.530142] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.530250] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.530283] tegradc 15210000.nvdisplay: Display dc.ffffff800be90000 registered with id=1
[ 1.530447] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.530456] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.534951] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.537873] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.538890] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.539724] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.541416] console [ttyTCU0] enabled
[ 1.541829] [drm] Initialized
[ 1.542830] tegradc 15210000.nvdisplay: probed
[ 1.543236] tegradc 15210000.nvdisplay: fb registered
[ 1.546705] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.546718] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.546734] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.546749] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.546782] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.546789] Extcon DP: HPD disabled
[ 1.546798] hpd: hpd_switch 0
[ 1.546824] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.546839] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.546856] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.558646] brd: module loaded
[ 1.564488] loop: module loaded
[ 1.564593] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.564732] tegra_profiler: auth: init
[ 1.565461] THERMAL EST: found 3 subdevs
[ 1.565478] THERMAL EST num_resources: 0
[ 1.565491] [THERMAL EST subdev 0]
[ 1.565501] [THERMAL EST subdev 1]
[ 1.565511] [THERMAL EST subdev 2]
[ 1.565526] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.565940] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.565949] THERMAL EST: thz register success.
[ 1.566090] THERMAL EST: end of probe, return err: 0
[ 1.566787] sd: No Scsi addr parsed to reserve index
[ 1.566827] hisi_sas: driver version v1.6
[ 1.576830] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.576840] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.576851] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.577049] 1 ofpart partitions found on MTD device spi6.0
[ 1.577061] Creating 1 MTD partitions on "spi6.0":
[ 1.577075] 0x000000000000-0x000002000000 : "Whole_flash0"
[ 1.579649] libphy: Fixed MDIO Bus: probed
[ 1.580600] tun: Universal TUN/TAP device driver, 1.6
[ 1.580611] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.581390] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.581402] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.581461] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.581471] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.581526] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.581534] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.581584] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.581592] Copyright(c) 1999 - 2017 Intel Corporation.
[ 2.517699] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 2.517708] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 7.247285] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 5 a2 df
[ 7.247450] libphy: dwc_phy: probed
[ 7.249569] PPP generic driver version 2.4.2
[ 7.249867] PPP BSD Compression module registered
[ 7.249874] PPP Deflate Compression module registered
[ 7.249893] PPP MPPE Compression module registered
[ 7.249900] NET: Registered protocol family 24
[ 7.249966] usbcore: registered new interface driver r8152
[ 7.250011] usbcore: registered new interface driver asix
[ 7.250053] usbcore: registered new interface driver ax88179_178a
[ 7.250086] usbcore: registered new interface driver cdc_ether
[ 7.250117] usbcore: registered new interface driver net1080
[ 7.250152] usbcore: registered new interface driver cdc_subset
[ 7.250188] usbcore: registered new interface driver zaurus
[ 7.250234] usbcore: registered new interface driver cdc_ncm
[ 7.250473] VFIO - User Level meta-driver version: 0.3
[ 7.251783] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 7.251815] ehci-pci: EHCI PCI platform driver
[ 7.251857] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 7.251872] ohci-pci: OHCI PCI platform driver
[ 7.251922] ohci-platform: OHCI generic platform driver
[ 7.256851] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 7.258858] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4c58800 id
[ 7.259474] usbcore: registered new interface driver uas
[ 7.259529] usbcore: registered new interface driver usb-storage
[ 7.259613] usbcore: registered new interface driver usbserial
[ 7.261231] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 7.261265] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.261285] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.262065] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 7.262109] tegra-xusb 3610000.xhci: irq 463, io mem 0x03610000
[ 7.262294] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.262302] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.262309] usb usb1: Product: xHCI Host Controller
[ 7.262315] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 7.262321] usb usb1: SerialNumber: 3610000.xhci
[ 7.262784] hub 1-0:1.0: USB hub found
[ 7.262828] hub 1-0:1.0: 4 ports detected
[ 7.263396] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.263408] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.263418] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.263627] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 7.263634] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.263640] usb usb2: Product: xHCI Host Controller
[ 7.263646] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 7.263652] usb usb2: SerialNumber: 3610000.xhci
[ 7.264172] hub 2-0:1.0: USB hub found
[ 7.264214] hub 2-0:1.0: 4 ports detected
[ 7.266130] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 7.266211] tegra-xudc-new 3550000.xudc: device count: 1
[ 7.267120] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 7.267142] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 7.267363] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 7.267374] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 7.268069] mousedev: PS/2 mouse device common for all mice
[ 7.268153] usbcore: registered new interface driver xpad
[ 7.400841] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 7.402467] Wake73 for irq=42
[ 7.403785] rtc rtc1: alarm rtc device
[ 7.403803] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 7.403831] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 7.403988] i2c /dev entries driver
[ 7.406631] i2c i2c-2: Added multiplexed i2c bus 9
[ 7.407233] i2c i2c-2: Added multiplexed i2c bus 10
[ 7.407242] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 7.407753] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 7.431333] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 7.431392] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 7.431648] imx219 9-0010: board setup failed
[ 7.431895] imx219: probe of 9-0010 failed with error -121
[ 7.432366] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 7.455643] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 7.455729] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 7.455969] imx219 10-0010: board setup failed
[ 7.456202] imx219: probe of 10-0010 failed with error -121
[ 7.457775] max77620-power max20024-power: Event recorder REG_NVERC : 0x77
[ 7.466130] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 7.470294] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 7.470329] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 7.470336] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 7.470450] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 7.470539] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 7.470545] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 7.470819] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 7.470894] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 7.470901] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 7.471228] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 7.471314] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 7.471322] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 7.471705] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 7.471772] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 7.471779] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 7.472073] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 7.472700] FAN dev name: pwm-fan
[ 7.472756] FAN:gpio request success.
[ 7.472773] FAN: can't find tach_gpio
[ 7.472786] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 7.472825] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 7.473053] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 7.473060] pwm_fan_driver pwm-fan: tach period: 1000
[ 7.473667] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 7.473675] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 7.473682] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 7.473688] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 7.473694] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 7.473700] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 7.473706] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 7.473712] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 7.473719] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 7.473726] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 7.475238] device-mapper: uevent: version 1.0.3
[ 7.475734] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 7.480167] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 7.481405] cpuidle: Initializing cpuidle driver
[ 7.482661] sdhci: Secure Digital Host Controller Interface driver
[ 7.482673] sdhci: Copyright(c) Pierre Ossman
[ 7.482680] sdhci-pltfm: SDHCI platform and OF driver helper
[ 7.484469] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 7.487756] CMDQ: cmdq_platfm_init successful
[ 7.493096] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 7.494936] tegra-se-nvhost 15810000.se: initialized
[ 7.496497] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 7.497270] tegra-se-nvhost 15820000.se: initialized
[ 7.498632] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 7.499706] tegra-se-nvhost 15830000.se: initialized
[ 7.500462] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 7.501263] tegra-se-nvhost 15840000.se: initialized
[ 7.502400] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 7.502634] hidraw: raw HID events driver (C) Jiri Kosina
[ 7.504008] usbcore: registered new interface driver usbhid
[ 7.504020] usbhid: USB HID core driver
[ 7.508121] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 7.509474] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 7.510171] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 7.510807] denver_knobs_init:MTS_VERSION:50168445
[ 7.511038] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 7.511604] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 7.511990] t19x_cache tegra-cache: probed
[ 7.514432] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 7.514441] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 7.515090] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 7.515538] PLL_AON clock registered
[ 7.516508] Clocks initialized successfully
[ 7.518044] nvpmodel: initialized successfully
[ 7.519131] trusty-virtio trusty:virtio: initializing
[ 7.519364] trusty_ipc virtio0: vring0: va(pa) ffffffc1f460a000(0) qsz 32 notifyid 1
[ 7.519379] trusty_ipc virtio0: vring1: va(pa) ffffffc1f4da4000(0) qsz 32 notifyid 2
[ 7.519519] trusty-virtio trusty:virtio: initializing done
[ 7.519687] trusty_ipc virtio0: is online
[ 7.520686] tegra-hda 3510000.hda: Override SDO lines to 4
[ 7.521046] usbcore: registered new interface driver snd-usb-audio
[ 7.529679] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 7.533888] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 7.534137] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 7.534364] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 7.534596] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 7.571658] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 7.585922] mmc0: periodic cache flush enabled
[ 7.585944] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 7.586495] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 7.586789] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 7.587013] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 7.591221] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 7.593650] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 7.594837] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 7.614534] usb 1-2: New USB device found, idVendor=0451, idProduct=8242
[ 7.614541] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 7.614546] usb 1-2: SerialNumber: 5D44C2FB65E3
[ 7.615266] hub 1-2:1.0: USB hub found
[ 7.615329] hub 1-2:1.0: 4 ports detected
[ 7.642790] OPE platform probe
[ 7.642920] OPE platform probe successful
[ 7.720978] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 7.721102] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 7.721210] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 7.721313] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 7.721430] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 7.721580] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 7.721792] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 7.721944] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 7.722064] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 7.722187] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 7.722305] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 7.722419] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 7.722557] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 7.722677] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 7.722828] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 7.722956] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 7.723043] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 7.723129] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 7.723213] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 7.723296] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 7.733660] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 7.752742] u32 classifier
[ 7.752755] Actions configured
[ 7.752836] Initializing XFRM netlink socket
[ 7.753458] NET: Registered protocol family 10
[ 7.754312] NET: Registered protocol family 17
[ 7.754351] NET: Registered protocol family 15
[ 7.754413] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 7.754501] Bluetooth: RFCOMM socket layer initialized
[ 7.754518] Bluetooth: RFCOMM ver 1.11
[ 7.754525] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 7.754535] Bluetooth: HIDP socket layer initialized
[ 7.754557] 9pnet: Installing 9P2000 support
[ 7.754600] Key type dns_resolver registered
[ 7.754864] Registered cp15_barrier emulation handler
[ 7.754888] Registered setend emulation handler
[ 7.755640] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 7.755647] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.757535] registered taskstats version 1
[ 7.758025] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 7.758955] OF: PCI: host bridge /pcie@14160000 ranges:
[ 7.758973] OF: PCI: IO 0x36100000..0x361fffff -> 0x36100000
[ 7.758982] OF: PCI: MEM 0x1740000000..0x17ffffffff -> 0x40000000
[ 7.758988] OF: PCI: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 7.761689] usb 1-2: usb_suspend_both: status 0
[ 7.869690] tegra-pcie-dw 14160000.pcie: link is up
[ 7.869982] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 7.870006] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 7.870018] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 7.870024] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 7.870029] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 7.870056] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 7.870227] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 7.870450] iommu: Adding device 0004:00:00.0 to group 58
[ 7.870761] pci 0004:01:00.0: [8086:24fd] type 00 class 0x028000
[ 7.870947] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 7.871829] pci 0004:01:00.0: PME# supported from D0 D3hot D3cold
[ 7.872172] iommu: Adding device 0004:01:00.0 to group 59
[ 7.882627] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 7.882639] pci 0004:01:00.0: BAR 0: assigned [mem 0x1740000000-0x1740001fff 64bit]
[ 7.882725] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 7.882734] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 7.882770] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 7.882831] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 7.883062] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 7.883066] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 7.883072] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 7.883168] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 7.883723] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 7.884662] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 7.884693] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 7.884701] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 7.884707] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 8.398769] tegra-pcie-dw 141a0000.pcie: link is down
[ 8.398960] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 8.398969] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 8.398976] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 8.398982] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 8.398987] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 8.399037] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 8.399198] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 8.399389] iommu: Adding device 0005:00:00.0 to group 60
[ 8.399729] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 8.399750] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.399961] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.399968] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 8.400062] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 8.400215] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 8.400309] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 8.400400] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 8.400555] iommu: Removing device 0005:00:00.0 from group 60
[ 8.400628] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 8.402262] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[ 8.413139] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[ 8.417834] tegra194-isp5 14800000.isp: initialized
[ 8.425280] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 8.428331] tegra194-vi5 15c10000.vi: initialized
[ 8.432833] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[ 8.432949] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[ 8.433776] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 8.515639] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 8.515972] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 8.516153] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 8.516369] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 8.516831] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 8.516925] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 8.517141] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 8.517146] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 8.518173] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 8.518651] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 8.518741] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 8.518897] input: gpio-keys as /devices/gpio-keys/input/input4
[ 8.550650] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:18 UTC (946688418)
[ 8.551114] mmcblk mmc0:0001: Card claimed for testing.
[ 8.590886] bpmp: mounted debugfs mirror
[ 8.597554] vdd-sdmmc1-sw: disabling
[ 8.597562] vdd-1v8-sd: disabling
[ 8.597566] vdd-1v8-cvb: disabling
[ 8.597569] vdd-epb-1v0: disabling
[ 8.597572] avdd-cam-2v8: disabling
[ 8.597575] vdd-fan: disabling
[ 8.597579] vdd_sys_en: disabling
[ 8.597588] ALSA device list:
[ 8.597591] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 8.597594] #1: jetson-xaviernx-ape
[ 8.599264] Freeing unused kernel memory: 8576K
[ 8.638482] Root device found: mmcblk0p1
[ 8.639824] Found dev node: /dev/mmcblk0p1
[ 8.862387] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[ 8.862396] EXT4-fs (mmcblk0p1): recovery complete
[ 8.866993] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.868019] Rootfs mounted over mmcblk0p1
[ 8.890648] Switching from initrd to actual rootfs
[ 8.985472] systemd[1]: System time before build time, advancing clock.
[ 9.008357] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 9.012289] cgroup: cgroup2: unknown option "nsdelegate"
[ 9.022291] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 9.023020] systemd[1]: Detected architecture arm64.
[ 9.029924] systemd[1]: Set hostname to <bts-kc3>.
[ 9.111066] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 9.111081] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 9.253074] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.256166] systemd[1]: Created slice System Slice.
[ 9.256359] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.256649] systemd[1]: Listening on Syslog Socket.
[ 9.256692] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.256861] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.256911] systemd[1]: Reached target User and Group Name Lookups.
[ 9.257592] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.333601] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 9.367928] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 9.639842] systemd-journald[2322]: Received request to flush runtime journal from PID 1
[ 10.575686] random: crng init done
[ 10.575810] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.587946] using random self ethernet address
[ 10.588077] using random host ethernet address
[ 10.680387] Intel(R) Wireless WiFi driver for Linux
[ 10.680397] Copyright(c) 2003- 2015 Intel Corporation
[ 10.680846] iwlwifi 0004:01:00.0: enabling device (0000 -> 0002)
[ 10.684061] iwlwifi 0004:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 10.684276] iwlwifi 0004:01:00.0: Falling back to user helper
[ 11.209324] Mass Storage Function, version: 2009/09/11
[ 11.209336] LUN: removable file: (no medium)
[ 11.215568] using random self ethernet address
[ 11.215701] using random host ethernet address
[ 11.257400] rndis0: HOST MAC d2:30:b4:7f:a3:bc
[ 11.257553] rndis0: MAC d2:30:b4:7f:a3:bd
[ 11.262199] usb0: HOST MAC d2:30:b4:7f:a3:be
[ 11.262243] usb0: MAC d2:30:b4:7f:a3:bf
[ 11.262274] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 11.270327] l4tbr0: port 1(rndis0) entered blocking state
[ 11.270338] l4tbr0: port 1(rndis0) entered disabled state
[ 11.270582] device rndis0 entered promiscuous mode
[ 11.276408] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 11.281990] l4tbr0: port 2(usb0) entered blocking state
[ 11.281999] l4tbr0: port 2(usb0) entered disabled state
[ 11.282237] device usb0 entered promiscuous mode
[ 11.294448] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 11.421171] android_work: did not send uevent (0 0 (null))
[ 11.427980] Wake76 for irq=199
[ 11.427989] Wake77 for irq=199
[ 11.427992] Wake78 for irq=199
[ 11.427995] Wake79 for irq=199
[ 11.427998] Wake80 for irq=199
[ 11.428001] Wake81 for irq=199
[ 11.428004] Wake82 for irq=199
[ 11.428042] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 11.428048] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 11.498982] android_work: sent uevent USB_STATE=CONNECTED
[ 11.550156] android_work: sent uevent USB_STATE=DISCONNECTED
[ 11.639729] usbcore: registered new interface driver btusb
[ 11.640709] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 11.641929] Bluetooth: hci0: Device revision is 16
[ 11.641936] Bluetooth: hci0: Secure boot is enabled
[ 11.641940] Bluetooth: hci0: OTP lock is enabled
[ 11.641943] Bluetooth: hci0: API lock is enabled
[ 11.641947] Bluetooth: hci0: Debug lock is disabled
[ 11.641951] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 11.646368] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 11.646969] android_work: sent uevent USB_STATE=CONNECTED
[ 11.660088] configfs-gadget gadget: high-speed config #1: c
[ 11.660121] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 11.660135] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 11.660146] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 11.660220] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 11.660232] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 11.660243] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 11.660272] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 11.660293] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 11.660312] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 11.660366] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 11.660532] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.667171] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 11.667190] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 11.667319] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 11.667467] tegra-xudc-new 3550000.xudc: ep 13 disabled
[ 11.667566] tegra-xudc-new 3550000.xudc: ep 8 disabled
[ 11.686860] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 11.686879] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 11.744707] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.758187] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[ 11.778107] usb 2-3: New USB device found, idVendor=0451, idProduct=8240
[ 11.778117] usb 2-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 11.779765] hub 2-3:1.0: USB hub found
[ 11.780178] hub 2-3:1.0: 4 ports detected
[ 11.786248] ras_fhi_disable: FHI 470 disabled
[ 11.786802] CPU2: shutdown
[ 11.786923] psci: CPU2 killed.
[ 11.839072] ras_fhi_disable: FHI 471 disabled
[ 11.845037] CPU3: shutdown
[ 11.861661] psci: Retrying again to check for CPU kill
[ 11.861682] psci: CPU3 killed.
[ 11.937687] usb 2-3: usb_suspend_both: status 0
[ 11.938255] ras_fhi_disable: FHI 472 disabled
[ 11.938450] usb usb2: usb_suspend_both: status 0
[ 11.938848] CPU4: shutdown
[ 11.938968] psci: CPU4 killed.
[ 11.982999] ras_fhi_disable: FHI 473 disabled
[ 11.989699] CPU5: shutdown
[ 12.009787] psci: Retrying again to check for CPU kill
[ 12.009807] psci: CPU5 killed.
[ 12.012699] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 12.485561] zram: Added device: zram0
[ 12.494159] zram: Added device: zram1
[ 12.579174] zram0: detected capacity change from 0 to 2037268480
[ 12.652288] Adding 1989516k swap on /dev/zram0. Priority:5 extents:1 across:1989516k SS
[ 12.675234] zram1: detected capacity change from 0 to 2037268480
[ 12.724545] Adding 1989516k swap on /dev/zram1. Priority:5 extents:1 across:1989516k SS
[ 13.127099] iwlwifi 0004:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 13.127355] iwlwifi 0004:01:00.0: Falling back to user helper
[ 13.266814] Bluetooth: hci0: Waiting for firmware download to complete
[ 13.267677] Bluetooth: hci0: Firmware loaded in 1589926 usecs
[ 13.267811] Bluetooth: hci0: Waiting for device to boot
[ 13.284738] Bluetooth: hci0: Device booted in 16568 usecs
[ 13.285259] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 13.288684] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 14.127448] tegradc 15200000.nvdisplay: blank - powerdown
[ 14.127464] tegradc 15210000.nvdisplay: blank - powerdown
[ 14.531150] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.531170] Bluetooth: BNEP socket layer initialized
[ 15.207624] fuse init (API version 7.26)
[ 15.494055] iwlwifi 0004:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 15.494271] iwlwifi 0004:01:00.0: Falling back to user helper
[ 15.943462] iwlwifi 0004:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 15.943675] iwlwifi 0004:01:00.0: Falling back to user helper
[ 15.979152] iwlwifi 0004:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 20.378192] net eth0: Failed to reset MAC
[ 20.385276] l4tbr0: port 2(usb0) entered blocking state
[ 20.385288] l4tbr0: port 2(usb0) entered forwarding state
[ 20.385344] l4tbr0: port 1(rndis0) entered blocking state
[ 20.385350] l4tbr0: port 1(rndis0) entered forwarding state
[ 20.385423] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 20.397511] iwlwifi 0004:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[ 20.400303] iwlwifi 0004:01:00.0: L1 Disabled - LTR Enabled
[ 20.400983] iwlwifi 0004:01:00.0: L1 Disabled - LTR Enabled
[ 20.519265] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 20.520208] thermal thermal_zone6: failed to read out thermal zone (-5)
[ 20.520380] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 20.964571] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 20.969859] iwlwifi 0004:01:00.0: L1 Disabled - LTR Enabled
[ 20.970174] iwlwifi 0004:01:00.0: L1 Disabled - LTR Enabled
[ 21.096279] iwlwifi 0004:01:00.0: L1 Disabled - LTR Enabled
[ 21.096592] iwlwifi 0004:01:00.0: L1 Disabled - LTR Enabled
[ 21.152985] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 21.376224] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 21.397678] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
Any other modules are working correctly.
Only two modules of them have problem like it.
