Eth1 static ip loss every 10 times after reboot
Dear all:
1: flash JP4.6_R32.6.1 for tx2 nx with our custom board,
eth1 using default driver r8168 for RTL8111G.
2: eth0 dhcp, eth1 static ip; eth0 is normal, eth1 static ip loss every 10 times. after rebot.
following file is syslog and kernel.log .
dmesg.log.zip (181.5 KB)
    2.1:  after apt-get autoremove isc-dhcp-client,   eth1 static ip is normal after 100 times test.
    2.2:  after flash JP4.6.4, eth1 static ip also loss every 10 times.
    2.3:  after falsh JP4.5.1, eth1 static  ip also accidental loss.
3 : eth0 static ip, eth1 dhcp: eth0 and eth1 normal every time.
Please help me indicate where this occasional phenomenon is caused。
Thank you very much. Best Regards.
Check the /var/log/syslog and see what is going on when the static ip is lsot.
the dmesg.log.zip file have syslog
Then please check by yourself.
