I want to establish an Ethernet Bus to send and receive image processing data (in real time) i have tried to connect two Orin’s with a point to point ethernet connection and i used socket programming to establish server on one side and the client on the other. but ethtools eth0 only shows me link
OK, i want to transfer data between multiple orin’s over an ethernet bus (switch or hub) but when i connect them with an ethernet cable it does not recognize the link connection. any advice on sending data with ethernet? (without using internet)
First, create a profile on the wired settings, connect an ethernet cable to it and set the ipv4 method to link-local only ( this will help with the interface to recognize the ethernet cable)
second, set IP addresses through the terminal with this command
sudo ip ad add 10.0.0.10/24 dev eth0
check if the firewall would allow tcp/ip connections through this
sudo ufw allow 22/tcp
third, when you want to transfer a file, use the scp command for example i transferred a file with this command, from orin1 to orin 2
