Ethernet camera data reading into Jetson TX1
Is it possible to read a video stream from an Ethernet camera connected to a host ubuntu machine into Jetson TX1?
I need to capture video from a GigE (Ethernet camera) into Jetson TX1 and do some pre-processing and use that video stream in my deep learning application. But as the application itself has some overhead, would it be feasible to connect the camera to a host ubuntu pc, capture the stream, preprocess and then read it into Jetson TX1?
Any inputs or pointers to solutions would be greatly appreciated.
Thanks,
Bharat
Hi BharatS,
A similar use case has been discussed, but it’s to read it into host Ubuntu PC.
You may refer to below topic to see if any help:
https://devtalk.nvidia.com/default/topic/930547/
Hey Bharat,
Were you able to stream your ethernet camera to the tx1? If so, how?
Thanks,
Jordan
