we can not make link up status between Lidar and Orin NX.
Lidar is 1000Base-T1 slaver, carrier board is 1000Base-T1 Master, Orin NX is setup in carrier board.
there is a switch from 1000Base-T1 to 1000-Base-Tx , then connect to Orin NX.
PHY chip set of 1000Base-T1 slaver is JL3113, 1000Base-T1 mater is LAN8871. They can not make linkup.
what is the method to link up this lidar with other kind of platform?
physical layer from Lidar is 1000Base-T1, input to Orin is Tx,
between them, there is switch. input of switch is 1000Base-T1, phy chipset is LAN8871. there is MCU configing the switch.
if we change the Lidar type, that’s meanning the phy chipset is not JL3113, they can linkup to LAN8871
I mean what is your method to link up lidar for some other platform like x86… we want to know that first so that we could check what is wrong with Jetson.
