Ethernet error, system reboot when using webcamera
Feb 13 12:37:39 nvidia-desktop kernel: [ 1713.603475] nvethernet 6810000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Feb 13 12:37:39 nvidia-desktop kernel: [ 1713.603494] Maximum registrations reached
Feb 13 12:38:13 nvidia-desktop kernel: [ 1747.223031] nvethernet 6810000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Feb 13 12:38:13 nvidia-desktop kernel: [ 1747.223049] Maximum registrations reached
Feb 13 12:38:33 nvidia-desktop kernel: [ 1767.054760] nvethernet 6810000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Feb 13 12:38:33 nvidia-desktop kernel: [ 1767.054780] Maximum registrations reached
Feb 13 12:38:50 nvidia-desktop kernel: [ 1784.918514] nvethernet 6810000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Feb 13 12:38:50 nvidia-desktop kernel: [ 1784.918533] Maximum registrations reached
Feb 13 12:39:21 nvidia-desktop kernel: [ 1815.030108] nvethernet 6810000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Feb 13 12:39:21 nvidia-desktop kernel: [ 1815.030128] Maximum registrations reached
Feb 13 12:39:50 nvidia-desktop kernel: [ 1844.645712] nvethernet 6810000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Feb 13 12:39:50 nvidia-desktop kernel: [ 1844.645731] Maximum registrations reached
Feb 13 12:40:24 nvidia-desktop kernel: [ 1878.769244] nvethernet 6810000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Feb 13 12:40:24 nvidia-desktop kernel: [ 1878.769263] Maximum registrations reached
Feb 13 12:40:47 nvidia-desktop kernel: [ 1901.072961] nvethernet 6810000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Feb 13 12:40:47 nvidia-desktop kernel: [ 1901.072981] Maximum registrations reached
Feb 13 12:41:12 nvidia-desktop kernel: [ 1926.044644] nvethernet 6810000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Feb 13 12:41:12 nvidia-desktop kernel: [ 1926.044663] Maximum registrations reached
Feb 13 12:41:25 nvidia-desktop kernel: [ 1939.352382] nvethernet 6810000.ethernet: Failed to report error: reporter ID: 0x0, Error code: 0x1001, return: -19
Feb 13 12:41:25 nvidia-desktop kernel: [ 1939.363077] nvethernet 6810000.ethernet: Failed to report error: reporter ID: 0x0, Error code: 0x1003, return: -19
Feb 13 12:41:31 nvidia-desktop kernel: [ 1945.496294] nvethernet 6810000.ethernet: Failed to report error: reporter ID: 0x0, Error code: 0x1001, return: -19
Feb 13 12:41:31 nvidia-desktop kernel: [ 1945.506986] nvethernet 6810000.ethernet: Failed to report error: reporter ID: 0x0, Error code: 0x1003, return: -19
Feb 13 12:41:37 nvidia-desktop kernel: [ 1951.640211] nvethernet 6810000.ethernet: Failed to report error: reporter ID: 0x0, Error code: 0x1001, return: -19
Feb 13 12:41:37 nvidia-desktop kernel: [ 1951.650902] nvethernet 6810000.ethernet: Failed to report error: reporter ID: 0x0, Error code: 0x1003, return: -19
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.599993] rcu: INFO: rcu_preempt self-detected stall on CPU
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.605917] rcu: 0-…: (1 GPs behind) idle=3ea/1/0x4000000000000004 softirq=250722/250723 fqs=2277
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615506] (t=5253 jiffies g=415917 q=7579)
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615508] Task dump for CPU 0:
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615511] task:irq/132-host_sy state:R running task stack: 0 pid: 167 ppid: 2 flags:0x0000002a
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615517] Call trace:
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615525] dump_backtrace+0x0/0x1d0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615528] show_stack+0x30/0x40
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615533] sched_show_task+0x148/0x170
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615539] dump_cpu_task+0x4c/0x58
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615542] rcu_dump_cpu_stacks+0xb8/0xf4
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615546] rcu_sched_clock_irq+0xb1c/0xe40
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615549] update_process_times+0x68/0xa0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615552] tick_sched_handle.isra.0+0x38/0x70
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615555] tick_sched_timer+0x54/0xb0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615556] __hrtimer_run_queues+0x148/0x380
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615559] hrtimer_interrupt+0xf0/0x250
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615563] arch_timer_handler_phys+0x40/0x50
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615565] handle_percpu_devid_irq+0x90/0x280
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615568] generic_handle_irq+0x40/0x60
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615571] __handle_domain_irq+0x70/0xd0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615573] gic_handle_irq+0x68/0x134
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615575] el1_irq+0xd0/0x180
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615577] skip_ftrace_call+0x4/0x30
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615582] iommu_pgsize.isra.0+0x2c/0x90
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615584] __iommu_unmap+0xa0/0x1d0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615586] iommu_unmap_fast+0x40/0x50
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615588] __iommu_dma_unmap+0x8c/0x110
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615590] iommu_dma_unmap_sg+0xb4/0xd0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615592] dma_unmap_sg_attrs+0x64/0xb0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615596] usb_hcd_unmap_urb_for_dma+0x9c/0x110
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615598] unmap_urb_for_dma+0x48/0x60
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615600] __usb_hcd_giveback_urb+0x44/0x140
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615602] usb_giveback_urb_bh+0xbc/0x120
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615606] tasklet_action_common.isra.0+0x138/0x180
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615608] tasklet_action+0x30/0x40
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615610] __do_softirq+0x140/0x3e8
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615612] irq_exit+0xc0/0xe0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615614] __handle_domain_irq+0x74/0xd0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615616] gic_handle_irq+0x68/0x134
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615618] el1_irq+0xd0/0x180
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615621] host1x_readl+0x44/0xd0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615624] syncpt_thresh_cascade_isr+0xd4/0x2b0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615627] irq_thread_fn+0x34/0xa0
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615630] irq_thread+0x158/0x250
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615633] kthread+0x148/0x170
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.615635] ret_from_fork+0x10/0x24
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.784144] nvethernet 6810000.ethernet: Failed to report error: reporter ID: 0x0, Error code: 0x1001, return: -19
Feb 13 12:41:43 nvidia-desktop kernel: [ 1957.794839] nvethernet 6810000.ethernet: Failed to report error: reporter ID: 0x0, Error code: 0x1003, return: -19
Sep 8 17:58:17 nvidia-desktop kernel: [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
Sep 8 17:58:17 nvidia-desktop kernel: [ 0.000000] Linux version 5.10.104-tegra (ubuntu@ubuntu-LenovoY7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Thu Dec 22 11:05:30 CST 2022
Sep 8 17:58:17 nvidia-desktop kernel: [ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
Sep 8 17:58:17 nvidia-desktop kernel: [ 0.000000] OF: fdt: - 80000000 , c0000000
Sep 8 17:58:17 nvidia-desktop kernel: [ 0.000000] Machine model: Jetson AGX Orin
Sep 8 17:58:17 nvidia-desktop kernel: [ 0.000000] efi: EFI v2.70 by EDK II
Sep 8 17:58:17 nvidia-desktop kernel: [ 0.000000] efi: RTPROP=0x805405a98 SMBIOS=0xffff0000 SMBIOS 3.0=0x8039a0000 MEMATTR=0x804768018 ESRT=0x803953018 RNG=0x827905998 MEMRESERVE=0x804771f18
Sep 8 17:58:17 nvidia-desktop kernel: [ 0.000000] efi: seeding entropy pool
please try to describe more about the scenario and environment.
We have 2 lidars, 1 gps and 1 camera use the etho.
The camera fps is 13, 13 * 5M per second. The data size of lidar and gps are not very big.
After all programs runs for several hours. The orin system reboot.
I feel your log probably not provides much help. Please try to use UART console to monitor the reboot cause.
And please try to reproduce your issue on devkit.
