I am using a custom carrier board based on Xavier AGX SOM. I am facing an issue with the Ethernet port LED as below.
Initially, we used the L4T32.6.1 and everything was good. if we connect the Ethernet cable to the Ethernet port, both the LEDs are blinking(yellow-on state, Green-blinking state).
Now I have migrated to L4T35.3.1 and I am facing an issue with one of the ethernet port LEDs. when I connect the cable to the ethernet port, the yellow LED is in the ON state and Green LED is in the OFF state. I can use the internet as usual, but the Green LED is not blinking.
I am expecting the GREEN LED should be blinking while using the internet (as same behaviour in L4T 32.6.1).
Could you please help me to solve this issue?
ethtool output:
Settings for eth0:
Supported ports: [ TP MII FIBRE ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: g
Wake-on: d
Link detected: yes
ifconfig output:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.9.159 netmask 255.255.254.0 broadcast 192.168.9.255
inet6 fe80::fd3f:24f1:961:392b prefixlen 64 scopeid 0x20<link>
ether 48:b0:2d:63:c6:4d txqueuelen 1000 (Ethernet)
RX packets 11783 bytes 10589264 (10.5 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 934 bytes 80375 (80.3 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Why is green led not working?
Thanks in advance,
Ashik P.
