Ethernet Initialization RH850U2A16 Thor Devkit
Software Version
DRIVE OS 7.0.3
other
Target Operating System
Linux
QNX
other
Hardware Platform
DRIVE AGX Thor Developer Kit (940-63960-0010-000)
DRIVE AGX Thor Developer Kit (940-63960-0012-000)
other
Host Machine Version
native Ubuntu Linux 24.04 Host installed with DRIVE OS Docker Containers
other
Issue Description
In NVIDIA_DriveOS_7.0.1_MCU_Reference_Guide/common/topics/mcu_sw_guide/mcu_ethernet_initialization.html is specified this “ Customer delivery contains only the template function (File: ethernet_device.c) for the switch initialization. You should add the required implementation for the network to function.”. I am working on a project using nvidia delivery for 7.0.2 and apps/cdds and i am stuck in eth working. I am releasing the resets for the 2 switches Realtek but when i am trying to ping using mbge3_0 i got host unreachable….since in the delivery package we dont have a EthTrcv, i really need the missing code in order to have eth working….we have the same switches as in the devkit → include “ethernet_device.h”
void Ethernet_Devices_Initialize(uint32 device)
/\*customer code\*/
void Ethernet_Devices_DeInitialize(uint32 device)
/\*customer code\*/
boolean Ethernet_Devices_Reg_Read(uint32 device, uint32 layeraddr, uint32 regaddr, uint32 *data)
/\*customer code\*/
boolean Ethernet_Devices_Reg_Write(uint32 device, uint32 layeraddr, uint32 regaddr, uint32 data, boolean is_32bit_enabled)
/\*customer code\*/
What i have to do so eth is working?
Error String
Logs
Dear @gabriele-andrea.blasciuc1 ,
Could you check with your project manager if you have any other support channel as 7.0.2 is not a DevZone release.
Despite 7.0.2 version, can you help me in filling the Ethernet_Devices_Initialize function for Realtek switches?
DRIVE OS 7.0.2 is not devzone release and it seems to be released via other channel. Could you please reach out to your PM to know right support channel on this issue?
